[SOLVED] Unable to upgrade PyTrack/FiPy firmware using Pycom Upgrade
I've been trying to upgrade my PyTrack + FiPy using the Pycom Upgrade tool that is available but every time I try to connect the board I keep getting "Could not connect to the board".
Tried changing the baud settings and check uncheck the different settings but to no avail.USB-driver is installed and I can access the device using REPL and also upload/download/run files without any problems at all but upgrading the firmware to get a SigFox Device ID and PAC is not working.
Using
zadiganddf-utilalso successfully updated the board so I'm clueless why I cannot upgrade.os.uname()returns following:sysname='FiPy', nodename='FiPy', release='1.20.1.r3', version='v1.11-58398d3 on 2019-12-12', machine='FiPy with ESP32', lorawan='1.0.2', sigfox='1.0.1', pybytes='1.3.0'I also don't seem to have a SigFox Device ID nor PAC as they come back as:
SigFox DeviceID: b'ffffffff' SigFox PAC: b'ffffffffffffffff'when using following code:
# print Sigfox Device ID print("SigFox DeviceID: ", binascii.hexlify(sigfox.id())) # print Sigfox PAC number print("SigFox PAC: ", binascii.hexlify(sigfox.pac()))Any ideas?
EDIT: Solved in https://forum.pycom.io/topic/5788/solved-v2-register-sigfox-returning-response-registersigfoxdevice-is-missing-some-arguments/5
The port must not be used by something else your IDE.
You may run into problems on a device with a high load.. In such a case, open the IDE, stop the script with ctrl-c, close the IDE and start the udate programm. But mind your watchdog. Your device may boot into high load again ;)
Was able to update the device using "Flash from local file" and using
Fipy-1.18.3.tarwhich flashed successfully and I got to the confirmation page saying DeviceID, LoRa Mac etc. but SigFox ID and PAC-fields are missing...Is there any other way to get the SigFox ID's in order to register the device on SigFox Backend?
Had to downgrade from 1.20.1.r3 to 1.18.3 due to
rtc.ntp_sync-simply not working using 1.20.1.r3
