    Preset variables in query parameters does not work for Webhook integration
    integrationbug
    1 Posts 1 Posters 111 Views 1 Watching
    • N Offline
      niels.reflektor
      I've tried to create a Webhook integration with the following parameters:
      HTTP Method: POST
      Request Format: Custom Body
      I find that preset variables does not work for the query parameters - the preset variable key string it just passed on without replacement. I.e. for DEVICE_NAME, I receive that very same string (DEVICE_NAME) at the end point.
      I notice that if I check the "use preset" checkbox and press save, the the box is unchecked when I review the configuration afterwards. I.e.
      Before Save:
      After Save, Edit:
      The preset variable replacement works fine for the Custom Body field.
      Can you help me with a solution?
      A side note: it would be very useful if it were also possible to use the preset parameters in the URL field.
      Thank you in advance.
