    Fipy, umqtt.simple library: check_msg() is blocking
    fipymqttmqtt bugsazurenb-iot
    4 Posts 4 Posters 278 Views 4 Watching
    • M Offline
      Mirox
      I'm using the umqtt.simple library to connect to the Azure IoT Hub and can successfully send messages to the topic, but when I call client.check_msg() to check if a message has been sent to the device, it's blocking my code when no message is sent instead of just returning if a message is in the queue or not.
      So when it get stucked at client.check_msg() and then I send a message to the device the message is printed and the code is continued.
      This is my code:
      client = MQTTClient(device_id, hostname, user=username, password=password, ssl=True, port=8883)
      topic = "devices/{device_id}/messages/events/".format(device_id=device_id)
      sub_topic = "devices/{device_id}/messages/devicebound/#".format(device_id=device_id)
      client.set_callback(sub_cb)
      client.connect()
      client.subscribe(sub_topic)
      print("subscribed")
      print("Start sending...")
      cntr = 0
      while (True):
          client.publish(topic, "message", qos=1)
          print("message sent\n")
          print("check messages\n")
          client.check_msg()      #At this point it get stucked when no message has been sent to the device
          cntr+=1
          time.sleep(20)
      Hardware: Fipy, Pytrack, NB-IoT is used to connect to the Azure IoT Hub
      • M Offline
        MarcosC
        @Mirox , how have you fix this? I have exactly the same issue and cannot fix it. The chec_msg() method get stucked. Thanks!
        • R Offline
          randomrnti @MarcosC
          @MarcosC I've had the same issue. The only workaround for me was to use non-SSL that's the only one that appears to work non-blocking.
            Alan Zhang
            Someone found a workaround - check out this github here: https://github.com/pycom/pycom-micropython-sigfox/issues/424
