    Function lora.ischannel_free(-100) get error
    5 Posts 3 Posters 233 Views 3 Watching
    • F Offline
      fernandes.son
      Does this function check the channel of the last transmission?
      TypeError: function takes 3 positional arguments but 2 were given
      Pycom MicroPython 1.20.2.rc6 [v1.11-01f49f7] on 2020-02-28; LoPy4 with ESP32
      Pybytes Version: 1.3.1
        jcaron @fernandes.son
        @fernandes-son another case of wrong documentation... the function requires a second argument which seems to be the time (in ms) the measurement has to be made.
        It happens here: https://github.com/pycom/pycom-micropython-sigfox/blob/Dev/esp32/mods/modlora.c#L2329
        F 1 Reply Last reply Reply Quote 2
        • F Offline
          fernandes.son @jcaron
          @jcaron Can you confirm if the return is based on the last packet received from the GW or not?
            @fernandes-son It uses self->frequency which is the same value as that returned by the lora.frequency method. self->frequency should be the same as lora_obj.frequency.
            Going very very quickly through the code it seems to be this would be more likely to be the frequency data was/is going to be sent on, but the lora_obj may be passed to other parts of the code.
            It should be easy to test, though, just call lora.frequency to see what it returns in various scenarios. Don't have a LoPy at hand to test this here at the moment.
              GregS @jcaron
