    Frozen Code, the Docker way
    esp32other
    2 Posts 2 Posters 170 Views 2 Watching
      Thosch42
      Hi all!
      Just a simple question: Can one build a Firmware with frozen code, like described in the pycom-libraries, using this docker container?
      I run docker on Windows 10. I start the whole thing from a normal command line with
      docker run -rm -v %cd%:/opt/frozen -it goinvent/pycom-fw build LOPY sc_frozen_0_2_0
      The whole thing runs fine, until it comes to 'make':
      LINK mpy-cross
         text    data     bss     dec     hex filename
       146051   15528     872  162451   27a93 mpy-cross
      Use make SECURE=on [optionally SECURE_KEY ?= secure_boot_signing_key.pem] to enable Secure Boot and Flash Encryption mechanisms.
      Use make V=1 or set BUILD_VERBOSE in your environment to increase build verbosity.
      make: *** No rule to make target 'release'.  Stop.
      mv: cannot stat '/tmp/*.tar.gz': No such file or directory
      So, is anyone out there, having this thing running 'out of the box'?
      Cheers,
      Thomas
        gazmcghee @Thosch42
        @Thosch42 I'm working on this https://github.com/buzzware/pycom-docker-firmware-build
        I can't vouch for it being correct or the output being functional or running on Windows, but it does complete the build on my Mac.
