    OTA updates: HTTP Server not working
    1 Posts 1 Posters 29 Views 1 Watching
    • R Offline
      railmonitor
      Hi.
      I am following the example in the documentation, as well as referencing this video from Pycom:
      https://www.youtube.com/watch?v=NnUVYIedl_w
      However, when running the server, either in CMD or in Visual Studio, it produces following error if i try to enter either:
      http://127.0.0.1:8000/manifest.json?current_ver=1.0.0
      or as suggested in the video:
      localhost:8000/manifest.json
      Error:
      I haven't changed a single line in the OTA.py or OTA_server.py, so what am i doing wrong?
      The directory that i am running the server from when using CMD has following structure:
      • server directory
        |- OTA_server.py
        |- 1.0.0
        | |- flash
        | | |- lib
        | | | |- OTA.py
        | | |- main.py
        | | |- boot.py
        | | |- config.py
        |- 1.0.1
        | |- flash
        | | |- lib
        | | | |- OTA.py
        | | |- main.py
        | | |- boot.py
        | | |- config.py
      To get the errors shown i had to go into Visual Studio and run the server, where the directory is not in this structure, but i am assuming that this is not the problem since running the server using CMD is not working.
      Another question: Ultimately i would like to be able to remotely update my code on the FiPy using LTE (NB-IoT) connection instead of WiFi. What will this require of changes? Obviously i must replace the Wifi part of the code, but wondering if someone has made this work / have an example of it?
