    Can't login to pybyte SSO anymore
    bugs
    5 Posts 2 Posters 66 Views 2 Watching
      trojanc
      Hi
      My username has a plus in the email address (username+alias@gmail.com), and this no longer works with SSO (https://sso.pycom.io/login). I can't log back in because it seems like some new validation is added to the website that doesn't allow a "+".
      I found the piece of code on the site using a web inspector to get around this issue for now....
      emailRules: [
        function (e) {
          return !!e || 'E-mail is required'
        function (e) {
         // FIXME - This expression is no good for usernames with a plus
          return /^\w+([.-]?\w+)*@\w+([.-]?\w+)*(\.\w{2,3})+$/.test(e) || 'E-mail must be valid'
      Please fix :'(
        trojanc
        anyone available to fix the website? I still can't do anything with pybytes since I can't log in. If you opensource your website I'll fix it for you ;) ....
        • ahmadelmasriA Offline
          ahmadelmasri
          Hello @trojanc,
          Sorry for the delay in reply. we will work to fix this issue as soon as possible.
          Please this type of issue should be reported using the below support link.
          https://pycom.io/community/contact-support/
          Thank you for your time.
          Ahmad EL Masri
            ahmadelmasri
            This issue is solved now.
            Thank you
            Ahmad EL Masri
            T 1 Reply Last reply Reply Quote 1
              trojanc @ahmadelmasri
              @ahmadelmasri Thanks so much! I can log in again!
