    Guru Meditation Error when connecting to Azure IoT-Hub.
    1 Posts 1 Posters 27 Views 1 Watching
    • R Offline
      railmonitor
      Hi.
      Getting the following error when i try to connect to Azure IoT-Hub using simple mqtt library:
      wondering what "ELF file SHA256: 000000000 etc." means?
      To be able to use the simple mqtt library i am using several different libraries, among them _sha256.py.
      Mind you the error is not consitent, it happens about 1/3 of the times i try to connect currently. Hard reset (removing USB power cable) typically solves the problem temporarily. Anyone has experience with this problem?
      Edit: I also got the error when disconnecting the LTE connection:
