    WLAN issue: wlan auto-connects upon entering function body
    1 Posts 1 Posters 84 Views 1 Watching
    • Y Offline
      yoplocheo
      I have a Pycom Lopy 4 that will recieve sensor readings from another MCU and structure the received data before sending it on to an MQTT server. To achieved that, I initialised the WLAN mode of my LoPy4 to 'STA_AP'.
      However, I realised that when i attempted a wlan.disconnect(), and my code enters a function block to deal with the data, wlan.isconnected() returns True again! I know this because I placed a few print statements within the function body to check for connectivity. Below is my code:
      import usocket
      from network import WLAN
      import ustruct
      from mqtt import MQTTClient
      sensor_dict = {
          0x77 : "bme280"
          # Add more sensors here #
      wlan = WLAN()
      ## Set static IP address for server
      wlan.ifconfig(id = 1, config=('192.168.0.104', '255.255.255.0', '192.168.0.1', '192.168.0.1'))
      ## Set WLAN mode to STA_AP (station & access point)
      print("Setting up wlan access point...")
      wlan.init(mode = WLAN.STA_AP, ssid = 'server_layer1', auth = (WLAN.WPA2, 'Password123'), channel=7, antenna=WLAN.INT_ANT)
      print("wlan mode set up: with WPA2 auth\n")
      ## -----------------------------This is the function block---------------------------------- ##
      def send_data(data_raw):
          print("Unpacking raw data...")
          data = ustruct.unpack('lifff', data_raw)
          loc, sensor_type, temp, press, hum = data
          if wlan.isconnected():
              print("connected1")
          ## Connect to internet
          wlan.connect("Name", auth=(WLAN.WPA2, "hahahahaha"), timeout=5000)
              print("connected3")
          while not wlan.isconnected():
              machine.idle()
          print("Connected to WiFi\n")
          print("Sending data up to MQTT server...")
          client = MQTTClient("xxx123", "io.adafruit.com",user="yoplo", password="xxx123", port=1883)
          client.connect()
          client.publish(topic="yoplo/feeds/{}/{}/temp".format(loc, sensor_dict[sensor_type]), msg=temp, retain = True)
      ## ---------------------------------End of function block------------------------------------- ##
      UDP_IP = "0.0.0.0"
      UDP_PORT = 6006
      ## Set up UDP socket and bind
      sock = usocket.socket(usocket.AF_INET,usocket.SOCK_DGRAM) ## UDP
      sock.bind((UDP_IP, UDP_PORT))
      print('Socket binded.')
      data_raw, addr = sock.recvfrom(24) ## buffer size is 24 bytes
      ## -----------------------------------ran wlan.disconnect() here--------------------------------##
      wlan.disconnect()
          print("connected2")
      send_data(data_raw)
      machine.deepsleep(10)
      My output was:
      Socket binded.
      raw data payload: b'q\x01\x00\x00w\x00\x00\x00\xe1z\xd0Aq\xedzD\x14\xae^B'
      source:  ('192.168.0.105', 49258)
      connected2
      connected1
      connected3
      Connected to WiFi
        File "main.py", line 65, in <module>
        File "main.py", line 43, in send_data
        File "/flash/lib/mqtt.py", line 66, in connect
      OSError: [Errno 113] EHOSTUNREACH
      Pycom MicroPython 1.18.2.r6 [v1.8.6-849-a210e85] on 2019-05-13; LoPy4 with ESP32
      'connected1' and 'connected3' were printed, although 'connected2' was not printed. Not sure why, appreciate any assistance!
