    FiPy and NB-IoT with new Pycom/Vodafone SIM
    1 Posts 1 Posters 66 Views 2 Watching
      patmolloy
      I have one of the new Sims. I have updated both the main firmware and the sequans firmware to the latest versions (sequans NB-IoT code). I have registered the sim in PyBytes and I think it all looks alive and good. The following code appears to suggest that the basic connectivity is there, but I get the following error .. can anyone help? It does look like that attach and connect are working!
      >>> Running selected lines
      Apparently attached
      Apparently connected
        File "<stdin>", line 18, in <module>
      OSError: [Errno 113] ECONNABORTED
      The code is ..
      import ssl
      from network import LTE
      lte = LTE()         # instantiate the LTE object
      lte.attach(band=20, apn="pycom.io")        # attach the cellular modem to a base station
      while not lte.isattached():
          time.sleep(0.25)
      print ("Apparently attached")
      lte.connect()       # start a data session and obtain an IP address
      while not lte.isconnected():
          time.sleep(0.25)
      print("Apparently connected")
      s = socket.socket()
      # s = ssl.wrap_socket(s)
      s.connect(socket.getaddrinfo('www.observat.io', 80)[0][-1])
      s.send(b"GET / HTTP/1.0\r\n\r\n")
      print(s.recv(4096))
      s.close()
      lte.disconnect()
      lte.dettach()
      The OSError is on line 18 which is the
