Can i read AWS certificates from a SD CARD?
Hello to all:
I'm following your tutorial for connect with AWS:
https://docs.pycom.io/tutorials/all/aws/
But i changed the lines for load the certificates in order to load them from SD CARD (i replace some words with *****):
AWS_PORT = 8883 AWS_HOST = "*******.amazonaws.com" AWS_ROOT_CA = "/sd/certificados/AmazonRootCA1.pem" AWS_CLIENT_CERT = "/sd/certificados/*****.cert.pem" AWS_PRIVATE_KEY = "/sd/certificados/*****.private.key"
Where i load from the SD card INSTEAD of flash memory (i have problems to accesing via FileZilla), but when i load the code an try to run it i get this error:
Socket create error: CA file not found
Besides i'm detecting the file from SD card:
#Listamos el contenido dentro de 'sd' sdContent = os.listdir('/sd/certificados') print('Leyendo contenido de la micro SD: ', sdContent)
And i get:
Leyendo contenido de la micro SD: ['start.ps1', 'VeriSign-Class 3-Public-Primary-Certification-Authority-G5.pem', 'AmazonRootCA1.pem', 'AmazonRootCA3.pem', '*****.cert.pem', '*****.private.key', '******.public.key']
Where i clearly access to sd card, but the board can't find the certificate.
How can i load certificates from SD card?
Thank you and sorry for the english
1 out of 1
