    Pinging a second device on the LAN - how to?
    2 Posts 2 Posters 85 Views 2 Watching
    • nigelwattrusN Offline
      nigelwattrus
      I have a pair of WiPys that I have been able to install on a common network with static IP addresses. This is a private network, I have no need to access the Internet. I would like to use ping to verify that I can "see" one WiPy from the other (and vice versa). Ultimately these devices will be sharing information between themselves (and other WiPys on the network). Although I have read that uping is the ping equivalent in Micropython I don't seem to be able to load it onto my WiPys. When I attempt to import uping the system complains that no such module exists. I guess I need to add this to /flash but where do I get the necessary file(s)?
      Some help would be much appreciated!
        robert-hh @nigelwattrus
        @nigelwattrus The original uping.py code is here: https://gist.github.com/shawwwn/91cc8979e33e82af6d99ec34c38195fb
        I had to adapt it for the pycom microypthon variant. Code below:
        # µPing (MicroPing) for MicroPython
        # copyright (c) 2018 Shawwwn <shawwwn1@gmail.com>
        # License: MIT
        # Internet Checksum Algorithm
        # Author: Olav Morken
        # https://github.com/olavmrk/python-ping/blob/master/ping.py
        # @data: bytes
        def checksum(data):
            if len(data) & 0x1: # Odd number of bytes
                data += b'\0'
            cs = 0
            for pos in range(0, len(data), 2):
                b1 = data[pos]
                b2 = data[pos + 1]
                cs += (b1 << 8) + b2
            while cs >= 0x10000:
                cs = (cs & 0xffff) + (cs >> 16)
            cs = ~cs & 0xffff
            return cs
        def ping(host, count=4, timeout=5000, interval=500, quiet=False, size=64):
            import utime
            import uselect
            import uctypes
            import usocket
            import ustruct
            import uos
            # prepare packet
            assert size >= 16, "pkt size too small"
            pkt = b'Q'*size
            pkt_desc = {
                "type": uctypes.UINT8 | 0,
                "code": uctypes.UINT8 | 1,
                "checksum": uctypes.UINT16 | 2,
                "id": (uctypes.ARRAY | 4, 2 | uctypes.UINT8),
                "seq": uctypes.INT16 | 6,
                "timestamp": uctypes.UINT64 | 8,
            } # packet header descriptor
            h = uctypes.struct(uctypes.addressof(pkt), pkt_desc, uctypes.BIG_ENDIAN)
            h.type = 8 # ICMP_ECHO_REQUEST
            h.code = 0
            h.checksum = 0
            h.id[0:2] = uos.urandom(2)
            h.seq = 1
            # init socket
            sock = usocket.socket(usocket.AF_INET, usocket.SOCK_RAW, 1)
            sock.setblocking(0)
            sock.settimeout(timeout/1000)
            addr = usocket.getaddrinfo(host, 1)[0][-1][0] # ip address
            sock.connect((addr, 1))
            not quiet and print("PING %s (%s): %u data bytes" % (host, addr, len(pkt)))
            seqs = list(range(1, count+1)) # [1,2,...,count]
            c = 1
            t = 0
            n_trans = 0
            n_recv = 0
            finish = False
            while t < timeout:
                if t==interval and c<=count:
                    # send packet
                    h.checksum = 0
                    h.seq = c
                    h.timestamp = utime.ticks_us()
                    h.checksum = checksum(pkt)
                    if sock.send(pkt) == size:
                        n_trans += 1
                        t = 0 # reset timeout
                        seqs.remove(c)
                    c += 1
                # recv packet
                while 1:
                    socks, _, _ = uselect.select([sock], [], [], 0)
                    if socks:
                        resp = socks[0].recv(4096)
                        resp_mv = memoryview(resp)
                        h2 = uctypes.struct(uctypes.addressof(resp_mv[20:]), pkt_desc, uctypes.BIG_ENDIAN)
                        # TODO: validate checksum (optional)
                        seq = h2.seq
                        if h2.type==0 and h2.id==h.id and (seq in seqs): # 0: ICMP_ECHO_REPLY
                            t_elasped = (utime.ticks_us()-h2.timestamp) / 1000
                            ttl = ustruct.unpack('!B', resp_mv[8:9])[0] # time-to-live
                            n_recv += 1
                            not quiet and print("%u bytes from %s: icmp_seq=%u, ttl=%u, time=%f ms" % (len(resp), addr, seq, ttl, t_elasped))
                            seqs.remove(seq)
                            if len(seqs) == 0:
                                finish = True
                                break
                        break
                if finish:
                    break
                utime.sleep_ms(1)
                t += 1
            # close
            sock.close()
            ret = (n_trans, n_recv)
            not quiet and print("%u packets transmitted, %u packets received" % (n_trans, n_recv))
            return (n_trans, n_recv)
        Call it for instance with:
        from uping import ping
        ping("www.google.com")
