Fipy freezes after two or three days. Using pytrack, Sigfox and DeepSleep
  • I want it for continuous monitoring. I did some tests with the following code, but after two or three days the code stops working and the blue light starts flashing. I want to send sensor data and coordinates using Sigfox every two hours and use the deep sleep function to save energy. I would greatly appreciate your help.
        from machine import Pin
        from onewire import DS18X20
        from onewire import OneWire
        from machine import UART
        from machine import ADC
        import math
        from network import Sigfox
        import network
        import os
        import utime
        import gc
        from machine import RTC
        from machine import SD
        from L76GNSS import L76GNSS
        from pytrack import Pytrack
        from crypto import AES
        import crypto
        import ubinascii
        #machine.reset()
        p_out = Pin('P9', mode=Pin.OUT)
        p_out.hold (False)
        p_out.value(0)
        p_out.hold (True)
        CountT=0
        ow = OneWire(Pin('P3'))
        temp = DS18X20(ow)
        while CountT<=5:
            DS18X20.start_conversion(temp)
            #time.sleep(1)
            #print(DS18X20.read_temp_async(temp))
            time.sleep(0.2)
            valor_T=str(DS18X20.read_temp_async(temp))
            limite_T=len(valor_T)
            #print("Temperatura: "+valor_T)
            CountT+=1
        #<------------Aqui va el codigo de micro sd
        py = Pytrack()
        l76 = L76GNSS(py, timeout=30)
        contador=0
        C=""
        Coordenadas=""
        Latitud=""
        Longitud=""
        contador=0
        #Pines: P10(TX)->RX(Verde) P11(RX)->TX(Azul) (EC,S,TDS) P3=Temperatura  P16->pH  P17-> Turbiedad  P8->Transistores
        # DS18B20 data line connected to pin P10
        #Objetos para el sensor de temperatura
        #Objetos para el sensor de Conducitvidad Altas Scientific
        uart = UART(1,9600,pins=('P10','P11'))#uart=UART(baudrate=9600,pins=('P12','P11'))# #P3=TX P4=RX
        #uart.init(9600, bits=8, parity=None, stop=1,)
        bajo = 0
        alto = 1
        w=''
        EC = ''
        TDS = ''
        Sal = ''
        pH = ''
        ntu = ''
        Condicion = True
        C=0
        T = ''
        #PM=Primer Mensaje
        while contador<=5:
            p_out.hold (False)
            p_out.value(1)
            p_out.hold (True)
            coord = l76.coordinates()
            #f.write("{} - {}\n".format(coord, rtc.now()))
            COORD="{}".format(coord)
            #print( COORD + str(contador))
            if COORD!="(None, None)":
                Coordenadas= "{}".format(coord)
                pycom.rgbled(0xFFCC00) # Amarillo                                 #
                pycom.rgbled(0x000000) # Apagado
                if Coordenadas!="":
                    if PM==1:
                        LC=len(Coordenadas)
                        #print(C)
                        while  alto <= LC:
                            digito = Coordenadas[bajo:alto]
                            if digito.isdigit():
                                Latitud = (Latitud + digito)
                            elif digito=="-":
                            elif digito==".":
                            elif digito==",":
                                bajo=alto
                                alto=bajo + 1
                                while alto <= LC:
                                        Longitud = (Longitud + digito)
                                    elif digito=="-":
                                    elif digito==".":
                                    elif digito==")":
                                        break
                                    bajo +=1
                                    alto +=1
                                break
                            bajo +=1
                            alto +=1
                        bajo=0
                        alto=1
                        #mensaje2=('Lat'+Latitud+'Lon'+Longitud)
                        #LonM=len(mensaje2)
                        #print(LonM)
                    pycom.rgbled(0xCC0000) # Rojo                                   #
                    pycom.rgbled(0x000000) # Azul Marino
        #-------------Midiento el pH-----------------
            x=0
            a = []
            while x<100:
                x+=1
                adc = ADC()
                # Set calibration - see note above
                adc.vref(1093)
                # Check calibration by reading a known voltage
                adc_c = adc.channel(pin='P16', attn=ADC.ATTN_11DB)
                #print(adc_c.voltage())
                a.append(adc_c.voltage())
                #print(a)
                #print(x)
                promediopH = sum(a)/100
            #print(int(promedio))
            m = 3/218
            b = -2416/218
            valor_ph = (promediopH*m)+b
            #valor_pH=valor_pH+0.35
            valor_ph=str(valor_ph)
            limite_ph=len(valor_ph)
            while  alto<= limite_ph and C<=4:
                digito_ph = valor_ph[bajo:alto]
                if digito_ph.isdigit():
                    pH = (pH + digito_ph)
                elif digito_ph=='.':
                    bajo=alto
                    alto=bajo + 1
                    while alto<=limite_ph and C<=4:
                        bajo +=1
                        alto +=1
                        C+=1
                bajo +=1
                alto +=1
            bajo = 0
            alto = 1
            C=0
        #-----------------Midiento la Turbiedad---------------------
            y=0
            b = []
            while y<100:
                y+=1
                adc = ADC()
                adc.vref(1093)
                adc_c = adc.channel(pin='P17', attn=ADC.ATTN_11DB)
                b.append(adc_c.voltage())
                #print(a)
                #print(x)
                promedioTur = sum(b)/100
                volt=promedioTur/1000
                volt = volt + 1.145
            volt=float(volt)
            RaizCuadradaV = math.pow(volt,2)
            if volt < 2.5:
                valor_ntu=3000
                valor_ntu=-1120.4*RaizCuadradaV +5742.3*(volt)-4352.8
            if valor_ntu <0:
                valor_ntu=0
            #print('Voltage: '+ str(volt))
            valor_ntu=str(valor_ntu)
            limite_ntu=len(valor_ntu)
            #print(valor_ntu)
            while  alto <= limite_ntu:
                digito_ntu = valor_ntu[bajo:alto]
                if digito_ntu.isdigit():
                    ntu = (ntu + digito_ntu)
                elif digito_ntu == '.':
                    #break
                bajo +=1
                alto +=1
            bajo = 0
            alto = 1
        #---------------Midiendo EC, TDS, Salinidad-------------------
            v=uart.read()
            #print('Tipo de dato: ' + str(type(y)))
            W = str(v)
            limite = len(W)
            #print(limite)
            for i in W:
                if str(i)=="r":
                    break
                #print(i)
                w=(w +str(i))
        #    while  alto <= limite:
                #digito = w[bajo:alto]
            #    if digito=="r":
                #    break
                #else:
                #    AtlasD = (AtlasD + digito)
                #bajo +=1
                #alto +=1
            #bajo = 0
            #alto = 1
            #limite=len(AtlasD)
            #print(w)
            limite=len(w)
            #print(limite)
            if limite>6:
                    #print("error")
                        EC = (EC + digito)
                    elif digito=='.':
                        EC = (EC + digito)
                    elif digito==',':
                        bajo=alto
                        alto=bajo + 1
                        while alto<=limite:
                            digito =w[bajo:alto]
                                TDS =  (TDS + digito)
                            elif digito=='.':
                            elif digito==',':
                                bajo=alto
                                alto=bajo+1
                                while alto<=limite:
                                    digito=w[bajo:alto]
                                        Sal = (Sal + digito)
                                    elif digito=='.':
                                    bajo +=1
                                    alto +=1
                            bajo +=1
                            alto +=1
                    bajo +=1
                    alto +=1
            #contador += 1
            #print(contador)
            #print(EC)
                bajo = 0
                alto = 1
        #-----------------Miediendo la temperatura---------------------
            #T = temp.read_temp_async()
            while  alto <= limite_T and C<=4:
                digito_T = valor_T[bajo:alto]
                if digito_T.isdigit():
                    T = (T + digito_T)
                elif digito_T=='.':
                    T = (T + digito_T)
                bajo +=1
                alto +=1
                C+=1
            bajo = 0
            alto = 1
            C=0
            T=T[0:5]
            #print("T: "+ T)
            limiteEC = len(str(EC))
            limiteTDS = len(str(TDS))
            limiteSal = len(str(Sal))
            print('Sensores: ' + EC + "---" +TDS+ "---" + Sal+ "---" + T+ "---" + ntu+ "---" + pH)
            #print(EC)
            if EC!= '' and TDS!='' and Sal!='':
                #if limiteEC <=7 and limiteTDS<=7 and limiteSal<=4:
                T=str(T)
                ntu=str(ntu)
                print('------------------------------------------------------------------------------------------------------')
                    #print('Datos totales: ' + w)
                    #print('EC: ' + EC)
                    #print('TDS: ' + TDS)
                    #print('Sal: ' + Sal)
                    #print('Temperatura: ' + T)
                    #print('NTU: ' + ntu)
                    #print("pH: "+ pH)
                    #print("valor_ph: "+ valor_ph)
                    #print(len(valor_ph))
                    #print(type(pH))
                print('contador: '+ str(contador))
                    #print('pH: ' + pH)
                    #print(valor_ph)
                pycom.rgbled(0x006600) # Azul cielo
                time.sleep(0.5)
                time.sleep(0.5)
                contador+=1
                Sensor1=EC
                Sensor2=TDS
                Sensor3=Sal
                Sensor4=T
                Sensor5=ntu
                Sensor6=pH
            w=''
            EC = ''
            TDS = ''
            Sal = ''
            pH= ''
            T=''
            ntu=''
        p_out.hold (False)
        p_out.value(0)
        p_out.hold (True)
        sd = SD()
        os.mount(sd, '/sd')
        C=os.listdir('/sd')
        print('Archivos dentro de la memoria: ' + str(C))  # imprime lo que tiene la memoria guardado.
        CL=len(C) #cantidad de archivos guardados en la memoria
        print('Numero de archivos encontrados: ' +str(CL))
        #time.sleep(1)
        if CL>0:
            Ci=1
            E=0
            D=''
            IDD=''
            D1=''
            D2=''
            while Ci<=CL:
                D=C[E]
                Dlon=len(D)
                IDD=D[0:4] #identificardor de datos en cada archivo
                if IDD=='hora':
                    D1=D
                    print('hora encontrada en memoria microSD: ' +str(D1))
                elif IDD=='coo0':
                    D2=D
                    print('No se enviaron las coordenadas: ' + str(D2))
                elif IDD=='coo1':
                    D2=D
                    print('Ya se enviaron las coordenadas: ' + str(D2))
                    print('Archivo ' + str(IDD) + ' no identificado...A')
                Ci+=1
                E+=1
            if D1=='':
                D1='hora1'
            if D2=='':
                D2='coo0'
            pycom.rgbled(0xFFCCCC) # Rojo
            os.fsformat('/sd')
            pycom.rgbled(0x000000) # Rojo
            print('memoria con datos')
            print('memoria vacia')
            D1='hora1'
            D2='coo0'
            print('Hora: '+ str(D1))
            print('Coor: '+ str(D2))
            D1L=len(D1)
        D1=D1[4:]
        D1=int(D1)
        #d1=D1
        D2=D2[3:]
        D2=int(D2)
        if D1<=12:
            D1+=1
        if D1>12:
            D1=1
            D2=0
        #else:
            #Latitud=""    #conseguir las coordenadas rapido
            #Longitud=""
        if Latitud!= ""  and Longitud != "":  #conseguir las coordenadas rapido
            E2=1
            print('Guardando el siguiente valor de hora:  ' + str(D1))
            print('Guardando el siguiente valor de coor:  ' + str(E2))
            d1=('hora' + str(D1))
            d2=('coo' + str(E2))
            f = open('/sd/'+ d1, 'a')
            f = open('/sd/'+ d2, 'a')
            C=os.listdir('/sd')
            #time.sleep(1)
            f.close()
            print('Completado... ' + str(C) )
            time.sleep(3)
            print('Guardando el siguiente valor de coor:  ' + str(D2))
            d2=('coo' + str(D2))
            C=os.listdir('/sd')
            #time.sleep(1)
            f.close()
            time.sleep(3)
            Paquetes = []
            if D2==0 and Latitud== ""  and Longitud == "":
                Paquetes.append(Sensor1)
                Paquetes.append(Sensor4)
                Paquetes.append(Sensor5)
                Paquetes.append(Sensor6)
            if D2==0 and Latitud!= ""  and Longitud != "":
                Paquetes.append(Latitud)
                Paquetes.append(Longitud)
            if D2==1 and Latitud != ""  and Longitud != "":
            if D2==1 and Latitud == ""  and Longitud == "":
            print('Paquetes: ' + str(Paquetes))
            for i in Paquetes:
                if i!='':
                    inicio = 0
                    fin = 1
                    key = b'Radikalsystems!!' # 128 bit (16 bytes) key
                    #iv = crypto.getrandbits(128) # hardware generated random IV (never reuse it)
                    cipher = AES(key, AES.MODE_ECB)  #ECB/CFB
                    mensaje=i
                    LonM=len(mensaje)
                    #print(Sensores6)
                    #print(LonM)
                    if LonM<16:
                        mensaje = (mensaje+ '/')
                        while LonM<16:
                            mensaje= (mensaje + mensaje[inicio:fin])
                            inicio+=1
                            fin+=1
                            #print(mensaje)
                            LonM=len(mensaje)
                            #print(len(mensaje))
                            #time.sleep(1)
                        inicio=0
                        fin=1
                    #print(mensaje)
                    msg =cipher.encrypt(mensaje)
                    hex_bytes=ubinascii.hexlify(msg)
                    #print(hex_bytes)
                    hex_str=hex_bytes.decode("ascii")
                    #print(hex_str)
                    LM=len(hex_str)
                    #print(LM)
                    Count=2
                    inicio=0
                    fin=2
                    NP=1  #Numero del paquete=NP
                    while Count <=LM:
                        Cint=1
                        paquete=[]
                        paquete.append(NP)  #NP=numero de paquete 1 ó 2
                        if len(Paquetes)>4:
                            P5=Paquetes[5]
                            P4=Paquetes[4]
                            if i == P5:
                                paquete.append(49)  #Numero de versión
                                paquete.append(111)  # 111=o  Longitud  6F  hex
                            if i == P4:
                                paquete.append(97)  # 97=a   Latitud    61 hex
                            color=0
                        P3=Paquetes[3]
                        P2=Paquetes[2]
                        P1=Paquetes[1]
                        P0=Paquetes[0]
                        color=1
                        if i == P3:
                            paquete.append(112)  #112=p    pH  70 hex
                        if i == P2:
                            paquete.append(110)  #110=n     ntc  6E hex
                        if i == P1:
                            paquete.append(84)  #84=T   Temperatura  54 hex
                        if i == P0:
                            paquete.append(69)  #69=E  Conductividad   45 hex
                        print('Agregando identificadores: ' + str(paquete))
                        while Cint<=8:  #8 son los esapcios que quedan disponibles para los datos dentro de los 12 bytes los primeros 4 bytes son identificadores Version/Sensor o corrdenadas/clave del sensro/num. de paquete.
                            #print('Hex: '+Hex[inicio:fin])
                            mensaje = (hex_str[inicio:fin])
                            Dec = int("0x"+mensaje, 16)
                            paquete.append(int((Dec)))
                            #print('Dec: '+ str(Dec))
                            #print(" ")
                            inicio+=2
                            fin+=2
                            Cint+=1
                            Count+=2
                            #time.sleep(1)
                            if inicio>=LM:
                                break
                        # init Sigfox for RCZ2 (Mexico)
                        sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ2)
                        # create a Sigfox socket
                        # make the socket blocking
                        s.setblocking(True)
                        # configure it as uplink only
                        s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
                        s.send(bytes(paquete))
                        print('Datos enviados a Sigfox: '+ str(paquete))
                        NP=int(NP)
                        NP+=1 # NP= Numero de Paquete
                        if color==1:
                            pycom.rgbled(0x109DFA) # Azul cielo                                   #
                            time.sleep(4)
                            pycom.rgbled(0x024A86) # Azul Marino
                            time.sleep(4)
                            time.sleep(4)
                            time.sleep(4)
                            pycom.rgbled(0x996633) # Amarillo oscuro
                            time.sleep(10)
                            pycom.rgbled(0x000000) # apagado
                        if color==0:
                            pycom.rgbled(0x660066) # Morado                               #
                            time.sleep(5)
                            time.sleep(5)
                            time.sleep(5)
                            pycom.rgbled(0x996633) # amarillo oscuro
                            time.sleep(11)
                    print('no se encontro el dato del sensor')
            print('Sueño profundo')
            machine.deepsleep (6926000)  # 7,200,000 = 2 horas  #25000 25 Segundos
  • Global Moderator
    I thought of something, now Im not sure this could be it, but its worth trying:
    • Try closing the socket after sending the data using s.close(), I believe there is no way to de-init the SigFox radio though.
    • Update to the latest firmware
      And indeed disable pybytes if it is enabled like @robert-hh suggested. It would indeed be interesting to see the log of a bad case.
    Best
  • @robert-hh said in Fipy freezes after two or three days. Using pytrack, Sigfox and DeepSleep:
    @Erick-Falcon Two questions:
    Is this log the good or the bad case?
    Do you need pybytes? If not, you may try disabling it with:
    pycom.pybytes_on_boot(False)
    And then reboot. The setting is permanent. If that does not work, create a file on you device called pybytes_config.json and the content:
    • good case
    • I don´t need pybytes.
  • @Erick-Falcon Two questions:
    • Is this log the good or the bad case?
    • Do you need pybytes? If not, you may try disabling it with:
    {"pybytes_autostart": false}
  • @robert-hh @Gijs
        ets Jun  8 2016 00:22:57
        rst:0x5 (DEEPSLEEP_RESET),boot:0x16 (SPI_FAST_FLASH_BOOT)
        configsip: 0, SPIWP:0xee
        mode:DIO, clock div:1
        load:0x3fff8020,len:8
        load:0x3fff8028,len:2140
        ho 0 tail 12 room 4
        load:0x4009fa00,len:19760
        entry 0x400a05bc
        Smart Provisioning started in the background
        See https://docs.pycom.io/smart for details
        Sensores: ---------31.06---3000---17.48418
        Sensores: ---------31.06---3000---17.45638
        Sensores: 0.00---0---0.00---31.06---3000---17.45156
        contador: 0
        Sensores: 0.00---0---0.00---31.06---3000---17.4228
        contador: 1
        Sensores: 0.00---0---0.00---31.06---3000---17.42197
        contador: 2
        Sensores: 0.00---0---0.00---31.06---3000---17.37587
        contador: 3
        Sensores: 0.00---0---0.00---31.06---3000---17.48225
        contador: 4
        Sensores: 0.00---0---0.00---31.06---3000---17.48046
        contador: 5
        Archivos dentro de la memoria: ['hora11', 'coo0']
        Numero de archivos encontrados: 2
        hora encontrada en memoria microSD: hora11
        No se enviaron las coordenadas: coo0
        memoria con datos
        Guardando el siguiente valor de hora:  12
        Guardando el siguiente valor de coor:  0
        Completado... ['hora12', 'coo0']
        Paquetes: ['0.00', '31.06', '3000', '17.48225']
        Agregando identificadores: [1, 49, 69]
        Datos enviados a Sigfox: [1, 49, 69, 229, 52, 158, 216, 116, 125, 107, 255]
        Agregando identificadores: [2, 49, 69]
        Datos enviados a Sigfox: [2, 49, 69, 18, 130, 192, 181, 226, 181, 115, 181]
        Agregando identificadores: [1, 49, 84]
        Datos enviados a Sigfox: [1, 49, 84, 121, 242, 116, 52, 205, 151, 49, 213]
        Agregando identificadores: [2, 49, 84]
        Datos enviados a Sigfox: [2, 49, 84, 131, 137, 127, 8, 32, 106, 118, 118]
        Agregando identificadores: [1, 49, 110]
        Datos enviados a Sigfox: [1, 49, 110, 187, 79, 190, 41, 196, 83, 242, 241]
        Agregando identificadores: [2, 49, 110]
        Datos enviados a Sigfox: [2, 49, 110, 18, 252, 1, 239, 192, 2, 237, 55]
        Agregando identificadores: [1, 49, 112]
        Datos enviados a Sigfox: [1, 49, 112, 150, 109, 117, 142, 125, 166, 14, 43]
        Agregando identificadores: [2, 49, 112]
        Datos enviados a Sigfox: [2, 49, 112, 199, 127, 103, 215, 213, 228, 128, 71]
        Sueño profundo
  • @Gijs said in Fipy freezes after two or three days. Using pytrack, Sigfox and DeepSleep:
    Based on what you are saying, did you upload the code to the device, or click run? After deepsleep, the code will re-enter at the top of boot.py and will continue to main.py. If both are empty, it will of course not continue. Do you have any information on why it crashes, coredumps or the like? Even after a crash, it should pick up the program at the top, disabling the heartbeat led. It could be the device running out of memory, or an issue with the sensor / GPS data that is not handled?
    I do not see any critical errors upon first look at your code.
    Let me know!
    I uploaded the code to the device, it works fine for a while but after 1 or 3 days it stops. I think if I connect the device to atom I can find what error appears, I'm on it.
    I don't think that is a memory problem, but How can I find out how much memory is available?, Is there a command for this?
  • Global Moderator
    @Erick-Falcon said in Fipy freezes after two or three days. Using pytrack, Sigfox and DeepSleep:
    import math
    import network
    import os
    import utime
    import gc
    import crypto
    import ubinascii
    #machine.reset()
    p_out.hold (False)
    p_out.value(0)
    p_out.hold (True)
    CountT=0
    temp = DS18X20(ow)
    while CountT<=5:
        #time.sleep(1)
        time.sleep(0.2)
        CountT+=1
    py = Pytrack()
    contador=0
    C=""
    Coordenadas=""
    Latitud=""
    Longitud=""
    contador=0
    bajo = 0
    alto = 1
    w=''
    EC = ''
    TDS = ''
    Sal = ''
    pH = ''
    ntu = ''
    Condicion = True
    C=0
    T = ''
    #PM=Primer Mensaje
    while contador<=5:
        p_out.hold (False)
        p_out.value(1)
        p_out.hold (True)
            if Coordenadas!="":
                if PM==1:
                    LC=len(Coordenadas)
                    #print(C)
                    while  alto <= LC:
                        elif digito=="-":
                        elif digito==".":
                        elif digito==",":
                            bajo=alto
                            alto=bajo + 1
                            while alto <= LC:
                                elif digito=="-":
                                elif digito==".":
                                elif digito==")":
                                    break
                                bajo +=1
                                alto +=1
                            break
                        bajo +=1
                        alto +=1
                    bajo=0
                    alto=1
                    #LonM=len(mensaje2)
                    #print(LonM)
        x=0
        a = []
        while x<100:
            x+=1
            adc = ADC()
            adc.vref(1093)
            #print(a)
            #print(x)
        m = 3/218
        b = -2416/218
                bajo=alto
                alto=bajo + 1
                    bajo +=1
                    alto +=1
                    C+=1
            bajo +=1
            alto +=1
        bajo = 0
        alto = 1
        C=0
        y=0
        b = []
        while y<100:
            y+=1
            adc = ADC()
            adc.vref(1093)
            #print(a)
            #print(x)
            volt = volt + 1.145
        volt=float(volt)
        if volt < 2.5:
            valor_ntu=3000
        if valor_ntu <0:
            valor_ntu=0
        #print(valor_ntu)
                #break
            bajo +=1
            alto +=1
        bajo = 0
        alto = 1
        v=uart.read()
        W = str(v)
        limite = len(W)
        #print(limite)
        for i in W:
            if str(i)=="r":
                break
            #print(i)
            w=(w +str(i))
        #    if digito=="r":
            #    break
            #else:
            #bajo +=1
            #alto +=1
        #bajo = 0
        #alto = 1
        #limite=len(AtlasD)
        #print(w)
        limite=len(w)
        #print(limite)
        if limite>6:
                #print("error")
                    EC = (EC + digito)
                elif digito=='.':
                    EC = (EC + digito)
                elif digito==',':
                    bajo=alto
                    alto=bajo + 1
                    while alto<=limite:
                        elif digito=='.':
                        elif digito==',':
                            bajo=alto
                            alto=bajo+1
                            while alto<=limite:
                                digito=w[bajo:alto]
                                elif digito=='.':
                                bajo +=1
                                alto +=1
                        bajo +=1
                        alto +=1
                bajo +=1
                alto +=1
        #contador += 1
        #print(contador)
        #print(EC)
            bajo = 0
            alto = 1
                T = (T + digito_T)
            elif digito_T=='.':
                T = (T + digito_T)
            bajo +=1
            alto +=1
            C+=1
        bajo = 0
        alto = 1
        C=0
        T=T[0:5]
        #print("T: "+ T)
        #print(EC)
            T=str(T)
            ntu=str(ntu)
                #print('EC: ' + EC)
                #print("pH: "+ pH)
                #print(type(pH))
                #print('pH: ' + pH)
                #print(valor_ph)
            time.sleep(0.5)
            time.sleep(0.5)
            contador+=1
            Sensor1=EC
            Sensor2=TDS
            Sensor3=Sal
            Sensor4=T
            Sensor5=ntu
            Sensor6=pH
        w=''
        EC = ''
        TDS = ''
        Sal = ''
        pH= ''
        T=''
        ntu=''
    p_out.hold (False)
    p_out.value(0)
    p_out.hold (True)
    sd = SD()
    os.mount(sd, '/sd')
    C=os.listdir('/sd')
    #time.sleep(1)
    if CL>0:
        Ci=1
        E=0
        D=''
        IDD=''
        D1=''
        D2=''
        while Ci<=CL:
            D=C[E]
            Dlon=len(D)
            if IDD=='hora':
                D1=D
            elif IDD=='coo0':
                D2=D
            elif IDD=='coo1':
                D2=D
            Ci+=1
            E+=1
        if D1=='':
            D1='hora1'
        if D2=='':
            D2='coo0'
        os.fsformat('/sd')
        D1='hora1'
        D2='coo0'
        D1L=len(D1)
    D1=D1[4:]
    D1=int(D1)
    #d1=D1
    D2=D2[3:]
    D2=int(D2)
    if D1<=12:
        D1+=1
    if D1>12:
        D1=1
        D2=0
    #else:
        #Longitud=""
        E2=1
        C=os.listdir('/sd')
        #time.sleep(1)
        f.close()
        time.sleep(3)
        C=os.listdir('/sd')
        #time.sleep(1)
        f.close()
        time.sleep(3)
        Paquetes = []
        for i in Paquetes:
            if i!='':
                inicio = 0
                fin = 1
                mensaje=i
                LonM=len(mensaje)
                #print(Sensores6)
                #print(LonM)
                if LonM<16:
                    while LonM<16:
                        inicio+=1
                        fin+=1
                        #print(mensaje)
                        LonM=len(mensaje)
                        #time.sleep(1)
                    inicio=0
                    fin=1
                #print(mensaje)
                #print(hex_bytes)
                #print(hex_str)
                LM=len(hex_str)
                #print(LM)
                Count=2
                inicio=0
                fin=2
                while Count <=LM:
                    Cint=1
                    paquete=[]
                    if len(Paquetes)>4:
                        P5=Paquetes[5]
                        P4=Paquetes[4]
                        if i == P5:
                        if i == P4:
                        color=0
                    P3=Paquetes[3]
                    P2=Paquetes[2]
                    P1=Paquetes[1]
                    P0=Paquetes[0]
                    color=1
                    if i == P3:
                    if i == P2:
                    if i == P1:
                    if i == P0:
                        #print(" ")
                        inicio+=2
                        fin+=2
                        Cint+=1
                        Count+=2
                        #time.sleep(1)
                        if inicio>=LM:
                            break
                    s.setblocking(True)
                    NP=int(NP)
                    if color==1:
                        time.sleep(4)
                        time.sleep(4)
                        time.sleep(4)
                        time.sleep(4)
                        time.sleep(10)
                    if color==0:
                        time.sleep(5)
                        time.sleep(5)
                        time.sleep(5)
                        time.sleep(11)
    Let me know!
