    Ghost watchdog
    watchdogpybytesmicropython
    9 Posts 2 Posters 111 Views 2 Watching
      tttadam
      Hello there,
      I am facing with a weird issue again.
      My wipy restart from time to time.
      machine.reset_cause() returns with 2 which is wdt_reset, but there is no watchdog object created in my code.
      Could this watchdog coming from pybytes or is it coming from Baskerville?
      Is there a way to find it?
        agotsis @tttadam
        @tttadam what does the following code return pycom.wdt_on_boot() ? It may be the case that the watchdog has been configured previously by another code. If this is True, set it to False, reboot the device and you're ok.
          tttadam @agotsis
          @agotsis It was False, I set it false again. So probably it was not it.
            tttadam
            Picture for proof :)
            There is no watchdog in the code neither.
              agotsis @tttadam
              @tttadam I would then propose to have a full flash erase of your module and see if the problem is still there (I know this is no actual solution, but has worked for me when I am seeing strange behavior)
                tttadam
                I did that.
                Updated the firmware with pycom firmware updater, erased everything during the process.
                BUT still reboots from time to time...
                ets Jun  8 2016 00:22:57
                rst:0x7 (TG0WDT_SYS_RESET),boot:0x37 (SPI_FAST_FLASH_BOOT)
                configsip: 0, SPIWP:0xee
                mode:DIO, clock div:1
                load:0x3fff8020,len:8
                load:0x3fff8028,len:2140
                ho 0 tail 12 room 4
                load:0x4009fa00,len:19760
                entry 0x400a05bc
                  tttadam @tttadam
                  @tttadam So I found a simular issue with a gpy I tried that solution.
                  I tried it and now infinite reboot... :D
                  flash read err, 1000
                  ets_main.c 371
                  ets_main.c 371
                  ets_main.c 371
                    tttadam
                    So I repetead the process again, now I change the filesytem also. No more bootloop.
                    We will see about the watchdog.
                      tttadam
                      sadly it's the same...
                      ho 0 tail 12 room 4
                      entry 0x400a05bc
