Trouble initiating pymesh on FiPy
I've been trying to run the pymesh examples on my FiPy for some time now, but I can't get it working - I get the error:Traceback (most recent call last): File "main.py", line 35, in <module> File "/flash/lib/pymesh.py", line 57, in __init__ File "/flash/lib/mesh_interface.py", line 56, in __init__ File "/flash/lib/mesh_internal.py", line 123, in __init__ File "/flash/lib/loramesh.py", line 73, in __init__ File "/flash/lib/loramesh.py", line 122, in _lora_init AttributeError: 'LoRa' object has no attribute 'Mesh'I know this problem has been occurring on previous firmware versions, and the solution was to update it to version 1.19, however I've already updated it and I am running the newest version:
Pycom MicroPython 1.20.2.rc10 [v1.11-a159dee] on 2020-06-26; FiPy with ESP32 Pybytes Version: 1.5.1I am running the pymesh_frozen/main.py from master of pycom libraries folder on github. The lib folder is taken from the same location. Am I missing something?
Also, I tried running the main-pybytes.py script on the other board which is connected to pybytes and there I got the error:AttributeError: 'NoneType' object has no attribute '__pymesh'in
pymesh = pybytes.__pymesh.__pymeshAny tips how to solve this? Both boards have the same firmware and pybytes version.
Ok, it seems I found the solution, which was just downgrading the firmware to 1.20.0rc10.
However, now I am experiencing the apparently known issue of Wi-Fi not working on legacy firmware (the WLAN.scan() function returns OSError: Scan operation failed)So - does anyone know which version of firmware has no issues with both pymesh and Wi-Fi connection?
