    Pytrack 2.0: firmware update
    5 Posts 3 Posters 135 Views 3 Watching
    • F Offline
      fgaultier
      We recently purchased two PyTrack2 and unfortunately we did not read the note, warning not to update its firmware.
      One board has thus been updated and does not work anymore and we urgently need a solution: could we get an early access to firmware V2 ?
      One the second board, we tested the latest version of theexample provided in the PyTrack 2 Library on GitHub, but we only get None values from the l76.coordinates() function: Has anyone experienced the same problem ?
      • R Offline
        rholas
        https://forum.pycom.io/topic/6068/pytrack-gps-none-none
          I have the correct firmware for you here: pytrack_app_v15.py (rename it to .dfu, as I am not able to upload .dfu files to the forum)
          F 1 Reply Last reply Reply Quote 2
          • F Offline
            fgaultier @Gijs
            @Gijs Many thanks !
            • F Offline
              fgaultier
              Everything works fine now with the 2.0 firmware. The default PyTrack 2 example also works fine now (just forgot the jumper to use the external antenna and pluging the external antenna without jumper seems to impair the internal antenna).
