Does LTE work in the USA?
I have the following code:
def lte_attach(): print("lte trying to attach") #lte.attach(band=13) lte.attach() while not lte.isattached(): time.sleep(0.5) #print('Attaching...') print('Attaching...', end='') send_at_cmd_pretty('AT+CEREG?') # get the System FSM print('**** lte attached ***********************') time.sleep(5)My output is simply:
Attaching... +CEREG: 2,4 OK Attaching... +CEREG: 2,4 OKSometimes, it will say CEREG: 2,0. I've rebooted the device, power cycled, and tried this on multiple days and its the same result. A few months ago, this same code actually worked. Nothing has changed on my end. Although at that time, I had to run this code for long periods of time before it would actually connect. I thought I was in the same situation now, but it has never resolved.
This last FSM report seems to have connected perfectly fine? The last message:
[(2, 1, 0, '', ('18.195.176.111', 80))]Is the output of the
socket.getaddrinfo()meaning the modem is able to do DNS lookup!
Best,
Just to confirm this lockup has happened more than once.
+--------------------------+--------------------+ | FSM | STATE | +--------------------------+--------------------+ | RRC TOP FSM |CONNECTED | | RRC SEARCH FSM |CAMPED | | RRC ACTIVE FSM |CONNECTED | | PMM PLMN FSM |NORM_CAMPED | | EMM MAIN FSM |REGISTERED_INIT | | EMM AUTH FSM |KASME_DEFINED | | EMM CONN FSM |AS_ESTABLISHED | | EMM TAU FSM |NULL | | EMM TEST FSM |NULL | | ESM BEARER FSM |BEARER_NULL_PENDING_ACTIVE| | SMS MT FSM |IDLE | | SMS MO FSM |IDLE | | HP MAIN FSM |IDLE | | HP USIM FSM |READY | | HP SMS MO FSM |IDLE | | HP SMS MT FSM |IDLE | | HP CAT FSM |IDLE | +--------------------------+--------------------+
@Gijs As you suggested, I have tried the examples again. Here they are with my results.
From https://docs.pycom.io/tutorials/networks/lte/
Example One
Changes from original are identified with # JFD
def example_one(): lte = LTE() lte.init() #some carriers have special requirements, check print(lte.send_at_cmd("AT+SQNCTM=?")) to see if your carrier is listed. #when using verizon, use #lte.init(carrier=verizon) #when usint AT&T use, #lte.init(carrier=at&t) #some carriers do not require an APN #also, check the band settings with your carrier #lte.attach(band=20, apn="your apn") lte.attach() #JFD Unknown print("attaching..",end='') # JFD while not lte.isattached() while not lte.isattached(): # JFD time.delay(0.25) utime.sleep_ms(25) print('.',end='') print(lte.send_at_cmd('AT!="fsm"')) # get the System FSM print("attached!") lte.connect() print("connecting [##",end='') while not lte.isconnected(): # JFD time.sleep(0.25) utime.sleep_ms(250) print('#',end='') #print(lte.send_at_cmd('AT!="showphy"')) print(lte.send_at_cmd('AT!="fsm"')) print("] connected!") # JFD Add delay utime.sleep_ms(250) # JFD print(socket.getaddrinfo('pycom.io', 80)) print(usocket.getaddrinfo('pycom.io', 80)) lte.deinit() #now we can safely machine.deepsleep()The above code loops continously in the
while not let.attached():stanza. It has the following output:SYSTEM FSM ========== +--------------------------+--------------------+ | FSM | STATE | +--------------------------+--------------------+ | RRC TOP FSM |SCANNING | | RRC SEARCH FSM |WAIT_RSSI | | RRC ACTIVE FSM |NULL | | PMM PLMN FSM |ANY_WAITCELL | | EMM MAIN FSM |NULL | | EMM AUTH FSM |NULL | | EMM CONN FSM |NULL | | EMM TAU FSM |NULL | | EMM TEST FSM |NULL | | ESM BEARER FSM |BEARER_NULL | | SMS MT FSM |IDLE | | SMS MO FSM |IDLE | | HP MAIN FSM |IDLE | | HP USIM FSM |READY | | HP SMS MO FSM |IDLE | | HP SMS MT FSM |IDLE | | HP CAT FSM |IDLE | +--------------------------+--------------------+ OKSince this is a hologram code, I have also tried with the following modification to the example:
lte.attach(apn="hologram"). In this case, it worked!!! (Possibly it also helped that during the time letting it run until lockup I also physically straightened the antenna fingers. They were curled so I put a sticky on each side of the fingers to hold straight.) The status settings are as below. In the all caps case, its the state when the code locked up.:- RRC TOP FSM: [CONNECTING], Scanning, Syncing, Camped, Camping,
 - RRC SEARCH FSM: [CAMPED], Wait RSSI, Wait Cell ID, Wait SIBX, Camped_Any,
 - RRC ACTIVE FSM: [Wait_SMC], Wait RSSI, Wait Cell ID, Wait SIBX, Camped_Any,
 - PMM PLMN FSM: [NORM CAMPED]
 - EMM MAIN FSM: [DEREG REGISTERING]
 - EMM AUTH FSM NULL
 - EMM CONN FSM [AS_ESTABLISHING]
 - EMM TAU FSM [NULL]
 - EMM TEST FSM [NULL]
 - ESM BEARER FSM [BEARER NULL PENDING ACTIVE]
 - SMS MT FSM [IDLE]
 - SMS MO FSM [IDLE]
 - HP MAIN FSM [IDLE]
 - HP USIM FSM [READY]
 - HP SMS NO FSM [IDLE]
 - HP SMS MT FSM [IDLE]
 - HP CAT FSM [IDLE]
What are these settings? Any references for the ignorant? I'm guessing FSM is finite state machine and these are possible states.
Afterwards, this happened at end.
[(2, 1, 0, '', ('18.195.176.111', 80))]Many thanks.
Maybe check out the example here: https://docs.pycom.io/tutorials/networks/lte/. Below, there is some sort of guide on the attaching sequence. Let me know of your result!
Best,
Do you have good coverage in your area?The signal is poor.
What SIM are you using?It was provided to me by someone else. I believe it is a hologram sim card.
What service (CAT-M1 or NB-IoT)?You got me. I don't know what that means. I am using the example code from the website on a pyfi. This is all that I am doing:
def lte_init(): lte.reset() lte.init() def lte_attach(): print("lte trying to attach") #lte.attach(band=13) lte.attach() while not lte.isattached(): time.sleep(0.5) #print('Attaching...') print('Attaching...', end='') send_at_cmd_pretty('AT+CEREG?') # get the System FSM print('**** lte attached ***********************') time.sleep(5) def lte_connect(): print("lte trying to connect") #lte.connect(cid=3) lte.connect() while not lte.isconnected(): time.sleep(0.5) print('Connecting...') # Now use sockets as usual... print('**** lte connected ***********************') time.sleep(5) def do_lte(): lte_init() lte_attach() lte_connect()This code worked earlier. Maybe two months ago. I haven't really tested it or modified it since then.
What antenna are you using?I don't know how to describe. It was provided to me. It appears to be this one:
@netskink Do you have good coverage in your area? What SIM are you using? What service (CAT-M1 or NB-IoT)? What antenna are you using? Is it connected to the right port?
