    ImportError: no module named 'globals' and no module named 'util'
    3 Posts 3 Posters 48 Views 3 Watching
      AlganEren
      link text
      code:
      import globals as g
      from machine import UART
      import sys
      import util
      from util import log
      from utime import sleep_ms, ticks_ms, ticks_diff
      uart = None
      #                     Send AT Command To Modem
      def at(cmd):
          try:
              if uart.any() > 0:
                  # get unsolicited modem response
                  a = get_modem_response()
                  if len(a) > 0:
                      log("unsolicited modem response: {}".format(a))
                  # process unsolicited results here
              log("  modem command: {}".format(cmd))
              # send command to modem
              n = uart.write(cmd + '\r')
              if n != len(cmd) + 1:
                  log("error sending command to modem: n = {}".format(n))
                  return []
          except Exception as ex:
              sys.print_exception(ex)
              a = []
          return a    # return modem response lines in array
      #             Attach Cellular Modem To Packet Domain Service
      def attach():
          try:
              log("attach modem to packet domain service")
              a = at('AT+CGATT=1')
              if a[0] != 'OK':
                  log("error attaching modem")
      #                       Check Registration
      def check_registration():
          # return 0-5, 99-unknown
          # response: ['+CEREG: 2,4', 'OK']
          # response: ['+CEREG: 2,1,"2C29","0B54400F",7', 'OK']
          # 2,0 - not registered, not searching
          # 2,1 - registered, home network
          # 2,2 - not registered, searching
          # 2,3 - registration denied
          # 2,4 - unknown (out of coverage)
          # 2,5 - registered, roaming
          try:
                  log("check registration")
                  a = at('AT+CEREG?')
                  if a[1] != 'OK':
                      break
                  s = a[0]
                  if (s[0:7] != "+CEREG:"):
                      break
                  a = s.split(",")
                  if (a[0] != "+CEREG: 2"):
                      break
                  reg = int(a[1])
                  if reg == 1:
                      log("registered - home network")
                  elif reg == 5:
                      log("registered - roaming")
                      log("not registered")
                  return reg
              log("check registration exception")
          # unknown registration
          log("error checking registration")
          return 99
      #             Detach Cellular Modem From Packet Domain Service
      def detach():
          try:
              log("detach modem from packet domain service")
              a = at('AT+CGATT=0')
              if a[0] != 'OK':
                  log("error detaching modem")
      #                       Disable LTE Modem
      def disable_modem():
          try:
              log("disable modem")
              at("AT+CFUN=4")     # disable both transmit and receive RF circuits
      #                       Enable Modem
      def enable_modem():
          try:
              log("enabling modem")
              a = at("AT+CFUN=1")     # full functionality
              if a[0] != 'OK':
                  log("error enabling modem")
      #                Get CFUN - Modem Level of Functionality
      def get_cfun():
          # 0 - minimum functionality
          # 1 - full functionality
          # 4 - radios disabled but access to SIM allowed
          # -1 - unknown
          # note: if modem does +SHUTDOWN/+SYSSTART, CFUN will be reset to 0
          try:
                  a = at('AT+CFUN?')
                  # response: ['+CFUN: 1', 'OK']
                  if a[1] != 'OK':
                      break
                  s = a[0]
                  if (s[0:6] != "+CFUN:"):
                      break
                  cfun = int(s[7])
                  return cfun
          return -1
      #                     Get Modem Response
      def get_modem_response():
          try:
              t0 = ticks_ms()
                  if uart.any() > 0:
                      # insure entire response has been received
                      sleep_ms(50)
                      break
                  t1 = ticks_ms()
                  tx = ticks_diff(t1, t0)
                  if tx > 10000:
                      log("timeout error - no modem response after 10 secs")
                      return []
                  sleep_ms(100)
              b = uart.read()
              s = str(b, 'utf-8')
              a = s.split('\r\n')
              a = list(filter(None, a))
              log("  modem response: {}".format(a))
              a = []
      #                           Get SMS Mode
      def get_sms_mode():
          # return 0-PDU mode or unknown, 1-text mode
          try:
              log("get SMS mode")
              a = at('AT+CMGF?')
              # response: ['+CMGF: 1', 'OK']
              if (len(a) < 2) or (a[1] != 'OK'):
                  return 0    # mode unknown
              s = a[0]
              if (s[0:6] != '+CMGF:'):
                  return 0    # state unknown
              mode = int(s[7])
              return mode
      #                            HTTP Post
      def http_post(uri, header, m):
          # POST <uri> HTTP/1.1
          # <header>
          # Content-Length: <len(m)>
          # Content-Type: application/octet-stream
          # <blank line>
          try:
              log("HTTP post")
                  # note: init_modem() is used to do "AT+SQNHTTPCFG=..."
                  n = len(m)
                  # log("writing message: {0}".format(m))
                  log("post message length: {0}".format(n))
                  # AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
                  # prof_id=1, command=0 (POST), post_parm="2" (application/octet-stream), header="Host: <host_name>"
                  a = at('AT+SQNHTTPSND=1,0,"{0}",{1},"2","{2}"'.format(uri, n, header))
                  if a[0] != '> ':
                      break
                  uart.write(m)
                  if a[0] != 'OK':
                      break
                  # modem responds with "+SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<data_size>"
                  s = a[0]
                  if s[0:13] != "+SQNHTTPRING:":
                      break
                  a = s.split(",")
                  n = int(a[3])
                  log("response message length: {0}".format(n))
                  # get response
                  cmd = 'AT+SQNHTTPRCV=1,0\r'
                  log("  modem command: {0}".format(cmd))
                  uart.write(cmd)
                  wait_rx(5, 10000)   # wait for b'\r\n<<<'
                  b = uart.read(5)
                  # log(" modem response: {0}".format(b))
                  if b[2:5] != b'<<<':
                      break
                  wait_rx(n, 10000)   # wait for response
                  b = uart.read(n)
                  if a[0] != 'OK':
                      break
                  log(b)
                  return b
          # some type of error occurred
          return b''
      #                     Get SIM Card ICCID Number
      def iccid():
          # modem must be registered to network to get ICCID
          try:
              log("get SIM card ICCID")
              a = at("AT+SQNCCID?")
              # example response: ['+SQNCCID: "89014103271203065543",""', 'OK']
              if a[1] != 'OK':
                  return ''
              s = a[0]
              if s[0:9] != '+SQNCCID:':
                  return ''
              a = s.split(",")
              n = len(a[0])
              r = a[0][11:n-1]
              r = ''
          log("ICCID = {0}".format(r))
          return r    # ICCID as string
      #                       Get Modem IMEI Number
      def imei():
          try:
              log("get modem IMEI number")
              a = at("AT+CGSN=1")
              # example response: ['+CGSN: "354347094028575"', 'OK']
              if a[1] != 'OK':
                  return ''
              s = a[0]
              if s[0:6] != '+CGSN:':
                  return ''
              n = len(s)
              r = s[8:n-1]
              r = ''
          log("IMEI = {0}".format(r))
          return r    # IMEI as string
      #                       Initialize Modem
      def init_modem():
          try:
              log("initializing modem")
              if uart == None:
                  init_uart()
              enable_modem()
              # set profile #1 parameters for HTTP connection
              # prof_id=1 (profile), ip, port, auth_type=0 (None), username="", password="",
              # ssl_enabled=0, timeout, cid=1 (PDN Context Identifier)
              server = g.oIni.host_ip     # note: host_name could also be used (auto DNS lookup)
              port = g.oIni.host_port
              timeout = 10    # secs to wait for response from server
              cmd = 'AT+SQNHTTPCFG=1,"{0}",{1},0,"","",0,{2},1'.format(server, port, timeout)
              a = at(cmd)
              if a[0] != 'OK':
                  log("error initializing modem")
              set_sms_mode()
      #               Initialize Uart Connected To LTE Modem
      def init_uart():
          global uart
          # pins=(TXD, RXD, RTS, CTS)
          # FiPy: pins=('P20', 'P18', 'P19', 'P17')
          # GPy:  pins=('P5', 'P98', 'P7', 'P99')
          log("initializing UART")
          # rx_buffer_size: must be > 127, 200000 works, 250000 crashes, http_post seems to work with any size
          uart = UART(1, baudrate=921600, bits=8, parity=None, stop=1, timeout_chars=2, pins=('P5', 'P98', 'P7', 'P99'), rx_buffer_size=512)
      #           Is Cellular Modem Attached To Packet Domain Service
      def isattached():
          # returns: True/False
          try:
              a = at('AT+CGATT?')
              if a[0][0:9] == '+CGATT: 1':
                  return True
          return False
      #                           Reset Modem
      def reset_modem():
          try:
              log("reseting modem...")
              a = at('AT^RESET')
              # generates +SHUTDOWN ... +SYSSTART responses
              if a[0] != 'OK':
                  log("error resetting modem")
              if a[1] != '+SHUTDOWN':
              if a[0] != '+SYSSTART':
      #                  Check Modem For Restart/Crash
      def restarted():
          # return True if modem has crashed / restarted
          try:
              # if CFUN != 1, modem has crashed / restarted
              r = get_cfun()
              if r != 1:
                  return True
              # if SMS text mode is reset to zero, modem has crashed / restarted
              mode = get_sms_mode()
              if mode != 1:
                  return True
              return False
          return True
      #                       Set SMS Mode To Text
      def set_sms_mode():
          try:
              log("set SMS mode to text")
              a = at('AT+CMGF=1')     # set SMS mode to text
              if a[0] != 'OK':
                  log("error setting SMS mode to text")
      #                       Get Signal Strength
      def signal_strength():
          # 0-31, 99-unknown
          try:
                  log("check signal strength")
                  a = at('AT+CSQ')
                  # example response: ['+CSQ: 18,99', 'OK'] where 18 is signal strength
                  if a[1] != 'OK':
                      break
                  s = a[0]
                  if (s[0:5] != "+CSQ:"):
                      break
                  n = len(s)
                  s = s[6:n-1]
                  a = s.split(",")
                  cell_signal = int(a[0])
                  g.oStatus.cell_signal = cell_signal
                  log("signal strength = {0}".format(cell_signal))
                  return cell_signal
          # unknown signal strength
          g.oStatus.cell_signal = 99
          log("signal strength unknown")
          return 99
      #             Delete Read, Sent, and Unsent SMS Messages
      def sms_delete():
          try:
              log("delete all READ, SENT, and UNSENT SMS messages")
              a = at('AT+CMGD=1,3')
              if a[0] != 'OK':
                  log("error trying to delete read, sent, and unsent SMS messages")
      #                     Delete All SMS Messages
      def sms_delete_all():
          # doesn't work until some time after lte.attach() is called
          try:
              log("delete all SMS messages")
              a = at('AT+CMGD=1,4')
              if a[0] != 'OK':
                  log("error trying to delete all SMS messages")
      #                     Process SMS Messages
      def sms_process(r):
          # example response:
          # ['+CMGL: 1,"REC READ","+19999999999",,"19/01/07,09:16:53-20"', 'Test3', '+CMGL: 2,"REC READ","+19999999999",,"19/01/07,11:12:30-20"', 'Test4', 'OK']
          try:
              for m in r:
                  if (m[0:5] == "+CMGL"):
                      continue
                  # process SMS messages
      #                      Read Unread SMS Messages
      def sms_read():
          # response example: ['+CMGL: 1,"REC UNREAD","+1999999999",,"19/01/07,09:16:53-20"', 'Test3', 'OK']
          a = at('AT+CMGL="REC UNREAD"')
          return a
      #                       Read All SMS Messages
      def sms_read_all():
          # response example:
          a = at('AT+CMGL="ALL"')
          return a
      #                       Wait For N Received Chars
      def wait_rx(n, timeout=10000):
          # timeout in msecs
          t0 = ticks_ms()
              if uart.any() >= n:
                  break
              t1 = ticks_ms()
              if tx > timeout:
                  return False
          return True
      #                    Wait For Specific Modem Response
      def wait_response(response, msecs=10000):
          log('wait up to {0} msecs for modem response: {1}'.format(msecs, response))
          t0 = ticks_ms()
              try:
                  a = at('AT')
                  for x in a:
                      if x == response:
                          log('****modem response found****: ' + response)
                          return True
                  t1 = ticks_ms()
                  log('{0} msecs'.format(tx))
                  if tx > msecs:
                      log('modem response not found: ' + response)
                      return False
                  sleep_ms(500)
      #                           Test #1
      def test1():
          try:
              log("test basic modem functions")
              if uart == None:
                  init_uart()
                  # reset_modem()
                  enable_modem()
                  set_sms_mode()
                  imei()
                  iccid()
                      r = check_registration()
                      if (r == 1) or (r == 5):
                          # modem registered
                          iccid()
                          attach()
                          return
                      if restarted():
                          print('MODEM crash/restart detected')
                          return
                      print(signal_strength())
                      sleep_ms(1000)
      #                         Example HTTP Get
      def test2():
          try:
              log("test HTTP get")
              at('AT+SQNHTTPCFG=1,"httpbin.org",80,0,"","",0,120,1')
              # some sites require "User-Agent" header
              #   ex: at('AT+SQNHTTPQRY=1,0,"/","User-Agent: Test1"')
              at('AT+SQNHTTPQRY=1,0,"/get"')
              at('AT+SQNHTTPRCV=1,0')
      #                         Example HTTP Post
      def test3(size=10):
          try:
              log("test HTTP post")
                  a = at('AT+SQNHTTPCFG=1,"httpbin.org",80,0,"","",0,120,1')
                  if a[0] != 'OK':
                      break
                  m = "X"*size
                  log("post message length: {0}".format(size))
                  a = at('AT+SQNHTTPSND=1,0,"/post",{0}'.format(size))
                  if a[0] != '> ':
                      break
                  uart.write(m)
                  if a[0] != 'OK':
                      break
                  s = a[0]
                      break
                  a = s.split(",")
                  n = int(a[3])
                  # get response
                  uart.write(cmd)
                  b = uart.read(5)
                      break
                  b = uart.read(n)
                  if a[0] != 'OK':
                      break
                  log(b)
                  return b
          return b''
      test1()
      I'm trying the code on the link but it doesn't recognize the global and util libraries. What can I do about this situation? Is it a firmware related situation? firmware: Pycom MicroPython 1.20.2.r0
      Can you guys help me?
      Thanks for all reply!!!
        I think the guy made his own file with credentials etc called 'globals', and 'utils' with different utility functions. They are not included in the firmware by default
        • K Offline
          kjm
          You can run globals without doing an import. For example
          if not 'lte' in globals(): lte=LTE()
          works on my gpy.
