    Pygate RX Sensitivity
    pygatesensitivitydocumentation
    4 Posts 3 Posters 66 Views 3 Watching
      d.alvrzx
      Hello all!
      I was wondering, how does the sensitivity of the Pygate compare to, say, the Laird RG1XX Gateways? The Laird modules have a stated sensitivity of -127 dBm (assuming Bandwidth = 125 kHz, Spreading Factor = 7, DR0), but I couldn't any similar parameter listed in the Pygate datasheet.
      Any ideas, @Gijs ? Or possibly somebody else :)
      Best,
      Dan
        @d-alvrzx said in Pygate RX Sensitivity:
        On the Pygate, we feature a Semtech SX1308 concentrator with SX1257 frontends. The combination has a theoretical sensitivity of -139dBm. I do not believe we measured the actual performance in this regard.
        Adding the SNR_min and Ptx, gives an even higher link budget :)
        D robert-hhR 2 Replies Last reply Reply Quote 1
          d.alvrzx @Gijs
          @Gijs Wow. -139 dBm seems very sensitive. I will look into it, do some tests with both GW and see how they compare. Will post back when that is done.
            robert-hh @Gijs
            @Gijs said in Pygate RX Sensitivity:
            IMHO this has not anything to do with the actual physics. It's just calculated numbers.
