    can't get PyMakr to start in VSCode
    6 Posts 4 Posters 98 Views 4 Watching
      dr_matt
      Already blown 1/2 a day trying to trouble shoot this and getting no where, please help!
      I followed the instructions on setting my PyMakr https://docs.pycom.io/gettingstarted/software/vscode/
      • I am using a Windows machine
      • I already had VScode installed with PlatformIO
      • I downloaded node.js 64 bit version, I couldn't get PyMakr to work, so removed and installed the 32 bit version as advised in Pycom trouble shooting. Both gave same result.
      • Confirmed Node is installed using node -v in command prompt (v12.18.3)
        This is odd as VScode is saying it is using version 12.14.1 of Node.js
      • VScode version is 1.49.00
      • PyMakr plugin is v1.1.6, it is installed globally
      • The PyMakr device is coming up as following COMM port
      I am not getting the blue bar down the bottom. I have a purple bar which is from Platform IO.
      Any help on what to do? Not sure where I have gone wrong. Thanks
      • B Offline
        benc
        I also have the issue since my VSCode updated to 1.49 (August 2020). Before this update, it was working.
        So I guess that the VSCode update has killed the PyMakr plugin, like has happened in the past
        If you manually install 1.48.2, it should work:
        https://code.visualstudio.com/updates/v1_48
        Then in settings, disable automatic updates.
        This worked for me. Will need to keep using 1.48.2 until Pycom release a fix for PyMakr
          dr_matt
            Thanks for notifying us! We were not aware of the issue. Ill notify the developers!
              dr_matt @benc
              @benc Yes, thanks, rolling back VScode one version worked. Appreciated!
              • ahmadelmasriA Offline
                ahmadelmasri
                Please check the new version 1.1.7!
                Ahmad EL Masri
