    Lopy4 : lora callback issue
    4 Posts 3 Posters 78 Views 3 Watching
      Thierry
      the code
      from network import LoRa
      def onReceive(interface):
          print("LoRa RX Event")
      lora_Interface = LoRa(LoRa.LORA, region=LoRa.EU868,
                            frequency = 868100000,bandwidth=LoRa.BW_125KHZ,
                            sf=7, coding_rate=LoRa.CODING_4_5,
                            preamble=8,  power_mode=LoRa.ALWAYS_ON,
                            public=False)
      lora_Interface.callback(trigger=LoRa.RX_PACKET_EVENT,
                              handler=onReceive)
      works well.
      But if I add at the end
             pass
      the callback is no longer run.
      If I stop using ctrl-c, the callback is called.
      Is this normal?
      Is the callback not an interrupt?
      Thierry
        d.alvrzx @Thierry
        @Thierry Something similar happened to me awhile back, but not with Lora callbacks, but with threads. I remember what I ended up doing was adding a short sleep (something like sleep_ms(10)) to the main loop. That way the loop would yield occasionally, and threads would execute correctly. Maybe try doing this?
        This is the thread where this was discussed: https://forum.pycom.io/topic/5805/main-thread-blocks-auxiliary-threads-_thread-module/6?_=1600903682512
          I think @d-alvrzx is correct here. You need some 'idle' time on the CPU for the callback to be registered. I believe its not a hardware routine that is used for the callback, but merely on top of the RTOS.
          T 1 Reply Last reply Reply Quote 2
            Thierry @Gijs
