    Erasing flash via pycom-fwtool-cli with barebones LoPy4
    6 Posts 3 Posters 133 Views 3 Watching
      d.alvrzx
      Hello all:
      I am attempting to erase the flash (and ultimately flash new firmware) to a LoPy4 that is barebones, connected to a breadboard, via the pycom-fwtool-cli tool. I currently have nothing else connected to the LoPy4 other than:
      • 5V power from external power supply
      • GND from external power supply
      • TX, RX and GND to an FTDI USB to Serial converter
      • GPIO0 (P2) connected to GND on boot (to enter bootloader mode)
      When entering bootloader mode, I get the following message:
      waiting for download
      However, when I run pycom-fwtool-cli.exe -p COM7 erase_all, I get the following output:
      Running in FTDI mode
      Erasing the board can take up to 40 seconds.
      Exception: Failed to connect to ESP32: Timed out waiting for packet header
      Is it possible to do these sort of commands without an Expansion board? I am testing this on a breadboard because I want to be able to do this on a PCB I am working on.
      I have already tested lowering the baud rate, but no luck!
      Maybe, @Gijs, could you help me out?
      Best,
      Dan
      • techykermitT Offline
        techykermit
        If you are able to connect to the device and run code, you can run
        import os
        os.fsformat("/flash")
        If fsformat() doesn't work, it's because Pycom has changed the function name several times. Also try with makefs and mkfs (with the same arguments) in case you have a lower version.
          robert-hh @d.alvrzx
          @d-alvrzx Yes, you can do that without an expansion board. Did you close all other software connected to the LoPy4 before starting pycom-fwtool-cli?
          You may also try to use esptool.py itself, which is the heart of pycom-fwtool-cli.py.
            d.alvrzx @robert-hh
            @robert-hh Thank you! So I uncovered what might be the problem: the commands coming from pycom-fwtool-cli only work once. Say, following this procedure:
            • Connect P2 to GND while LoPy4 powered off
            • Power on LoPy4
            • Send pycom-fwtool-cli -p COM7 erase_all command
              • This command works, flash is erased in 15.98 seconds
            • Send pycom-fwtool-cli -p COM7 flash -t LoPy4-1.20.2.rc6.tar.gz to flash new firmware
              • This command does not work, throws Exception: Failed to connect to ESP32: Timed out waiting for packet header
            • Restart LoPy4 with P2 to GND
            • Try pycom-fwtool-cli -p COM7 flash -t LoPy4-1.20.2.rc6.tar.gz again
              • This command works, firmware is flashed correctly.
            So it seems I need a reset between each command? Is this how it should work?
            EDIT: And yes, I did close all other software before opening the pycom fwtool.
              robert-hh @d.alvrzx
              @d-alvrzx You do not have to erase flash everytime you upload new firmware. Only if you think the flash is corrupted.
              Besides that there is the -c option which you could try.
                d.alvrzx @robert-hh
                @robert-hh Thanks for the mention of the -c option! I did not know this, but it works! No more resets needed between commands.
                And yes, I understand that I do not need to erase the flash every time I load a new firmware. But my example was trying to show that any 2 commands in a row had the same behaviour, for example:
                1. Run pycom-fwtool-cli -p COM7 lpwan
                  • The correct output is shown, with the SMAC, SID, PAC and LORA REGION
                2. Run pycom-fwtool-cli -p COM7 lpwan once again, without resetting LoPy
                  • The same error occurs: Exception: Failed to connect to ESP32: Timed out waiting for packet header
                Now, with the -c option enabled, the procedure above works! Thanks so much!
