Simpoint CAT-M1 through KPN in Germany
Hello together,
I got a simcard from Simpoint and wanted to try, If I can get LTE-M connectivity with that one too in Germany, so that there is an alternative to 1nce.
Simpoint offering CAT-M1 through KPN
I got the following firmware for my GPy:
>>> import sqnsupgrade >>> sqnsupgrade.info() <<< Welcome to the SQN3330 firmware updater [1.2.6] >>> >>> GPy with firmware version 1.20.2.r3 Your modem is in application mode. Here is the current version: UE5.0.0.0d LR5.1.1.0-47510The APN is simpoint.m2m. I've tried both methods with only lte.attach() and using the actual APN, but no success with a connection while I have a really great signal.
try: #lte.attach() lte.attach(apn="simpoint.m2m") while not lte.isattached(): time.sleep(1) print('.', end='') # indicates new loop iteration in Terminal output print(lte.send_at_cmd('AT!="fsm"')) print(lte.send_at_cmd("AT+CSQ")) print("[LTE] attached") except: print("[LTE] attach() (except). Reset board ...") machine.reset()I don't know, where the issue is. Does anybody have some advice?
. SYSTEM FSM ========== +--------------------------+--------------------+ | FSM | STATE | +--------------------------+--------------------+ | RRC TOP FSM |CAMPED | | RRC SEARCH FSM |CAMPED | | RRC ACTIVE FSM |IDLE | | PMM PLMN FSM |NORM_CAMPED | | EMM MAIN FSM |NULL | | EMM AUTH FSM |NULL | | EMM CONN FSM |NULL | | EMM TAU FSM |NULL | | EMM TEST FSM |NULL | | ESM BEARER FSM |BEARER_NULL | | SMS MT FSM |IDLE | | SMS MO FSM |IDLE | | HP MAIN FSM |IDLE | | HP USIM FSM |READY | | HP SMS MO FSM |IDLE | | HP SMS MT FSM |IDLE | | HP CAT FSM |IDLE | +--------------------------+--------------------+ OK +CSQ: 10,99 OK . SYSTEM FSM ========== +--------------------------+--------------------+ | FSM | STATE | +--------------------------+--------------------+ | RRC TOP FSM |CAMPED | | RRC SEARCH FSM |CAMPED | | RRC ACTIVE FSM |IDLE | | PMM PLMN FSM |NORM_CAMPED | | EMM MAIN FSM |NULL | | EMM AUTH FSM |NULL | | EMM CONN FSM |NULL | | EMM TAU FSM |NULL | | EMM TEST FSM |NULL | | ESM BEARER FSM |BEARER_NULL | | SMS MT FSM |IDLE | | SMS MO FSM |IDLE | | HP MAIN FSM |IDLE | | HP USIM FSM |READY | | HP SMS MO FSM |IDLE | | HP SMS MT FSM |IDLE | | HP CAT FSM |IDLE | +--------------------------+--------------------+ OK +CSQ: 10,99 OK . SYSTEM FSM ========== +--------------------------+--------------------+ | FSM | STATE | +--------------------------+--------------------+ | RRC TOP FSM |CAMPED | | RRC SEARCH FSM |CAMPED | | RRC ACTIVE FSM |IDLE | | PMM PLMN FSM |NORM_CAMPED | | EMM MAIN FSM |NULL | | EMM AUTH FSM |NULL | | EMM CONN FSM |NULL | | EMM TAU FSM |NULL | | EMM TEST FSM |NULL | | ESM BEARER FSM |BEARER_NULL | | SMS MT FSM |IDLE | | SMS MO FSM |IDLE | | HP MAIN FSM |IDLE | | HP USIM FSM |READY | | HP SMS MO FSM |IDLE | | HP SMS MT FSM |IDLE | | HP CAT FSM |IDLE | +--------------------------+--------------------+ OK +CSQ: 10,99 OK . SYSTEM FSM ========== +--------------------------+--------------------+ | FSM | STATE | +--------------------------+--------------------+ | RRC TOP FSM |CAMPED | | RRC SEARCH FSM |CAMPED | | RRC ACTIVE FSM |IDLE | | PMM PLMN FSM |NORM_CAMPED | | EMM MAIN FSM |NULL | | EMM AUTH FSM |NULL | | EMM CONN FSM |NULL | | EMM TAU FSM |NULL | | EMM TEST FSM |NULL | | ESM BEARER FSM |BEARER_NULL | | SMS MT FSM |IDLE | | SMS MO FSM |IDLE | | HP MAIN FSM |IDLE | | HP USIM FSM |READY | | HP SMS MO FSM |IDLE | | HP SMS MT FSM |IDLE | | HP CAT FSM |IDLE | +--------------------------+--------------------+ OK +CSQ: 11,99 OK
