    Pycom Firmware Upgrade - Failed to connect to ESP32: Timed out
    upgrade firmwlopy4 firmware
    3 Posts 2 Posters 159 Views 2 Watching
      Alephus
      Good evening
      Tryed to upgrade the firmware on a Lopy4 + 3.1 expansion board and it seems i was unable to no matter what i tryed.
      Details:
      -OS: Windows 10
      -Checked COM port, and the port selected is the correct one
      -Can connect to devices to upload/download code trough USB + IDE like Atom
      -Have the latest version of the upgrade tool
      -IDE is closed when tool is open
      The error occurs when the tool tries to read information about the board with the following error:
      i do note that from the moment i try to use the tool, the expansion board led indicator named "LED" is blinquing quickly.
      When the error happens, if i imediatly close the tool and open the IDE to see the output of the device, it seems he is in a loop with this mensage:
      only way to get the LoPy to come back to normal is to either unpower it or by pressing the reset button on board.
      Any sugestions?
      extra note: was able to use the tool on a complitely diferent lopy4 and board the day before, so drivers or windows bugs shoulnt be a problem
        I have not seen this issue before, but it seems the device is stuck in a boot loop as it could not find a bootloader at 0x1000. Now this can (probably) be fixed when using the command line interface: https://docs.pycom.io/advance/cli/ but Im not 100% sure
        A 1 Reply Last reply Reply Quote 1
          Alephus @Gijs
          @Gijs will try, i dont have much experience with the cli. Any positive results i will post here. Meanwhile any others tips are welcome
