Guru Meditation Error Dumps
I am getting frequent crashes with any code that uses interrupts or threads and thought that I would create a thread recording the crashes that I (and others) encounter so that they can be investigated and hopefully fixed.
Hardware: WIPY2
FW Version: 1.5.0.b2Checksum Error Guru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled. Register dump: PC : 0x400e9598 PS : 0x00060b30 A0 : 0x800e95ec A1 : 0x3ffe1850 A2 : 0x3ffe43f0 A3 : 0x00000001 A4 : 0x00000000 A5 : 0x3ffe1870 A6 : 0x400dbf40 A7 : 0x3ffc1068 A8 : 0x800e9598 A9 : 0x3ffe1830 A10 : 0x0000000d A11 : 0x00060b23 A12 : 0x00060b20 A13 : 0xb33f0000 A14 : 0xb33fffff A15 : 0x00060923 SAR : 0x00000013 EXCCAUSE: 0x0000001c EXCVADDR: 0x0000001d LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff Backtrace: 0x400e9598:0x3ffe1850 0x400e95ec:0x3ffe1870 0x400dbf50:0x3ffe18a0 0x400e071f:0x3ffe18c0 0x400d7e80:0x3ffe1940 ets Jun 8 2016 00:22:57===
Hardware: WIPY2
FW Version: 1.5.0.b2Guru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled. Register dump: PC : 0x400f3f6c PS : 0x00060e30 A0 : 0x800ecfcd A1 : 0x3ffd3860 A2 : 0x00000005 A3 : 0x3ffe1bd4 A4 : 0x00000008 A5 : 0xffffff30 A6 : 0x3ffe1b90 A7 : 0x00000000 A8 : 0x3f40c990 A9 : 0x3ffd3850 A10 : 0x00000000 A11 : 0x3ffc3cd0 A12 : 0x3ffc3c8c A13 : 0x3ffd38f0 A14 : 0x3ffd3888 A15 : 0x3ffd38f0 SAR : 0x00000020 EXCCAUSE: 0x0000001c EXCVADDR: 0x00000005 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x00000000 Backtrace: 0x400f3f6c:0x3ffd3860 0x400ecfcd:0x3ffd3900 0x400e95a8:0x3ffd3940 0x400e95d5:0x3ffd3960 0x400d8908:0x3ffd3980 0x400d8bd3:0x3ffd3a10 0x400d7bf0:0x3ffd3a30 ets Jun 8 2016 00:22:57===
Hardware: WIPY2
FW Version: 1.5.1.b1Sock Error: <class 'OSError'> I (41435) wifi: state: run -> init (0) I (41436) wifi: n:6 0, o:6 0, ap:255 255, sta:6 0, prof:6 I (41436) wifi: pm stop, total sleep time: 0/22889789 ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0x00 clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:QIO, clock div:2 load:0x3fff9010,len:8 load:0x3fff9018,len:268 ho 0 tail 12 room 4 load:0x40078000,len:2656 load:0x4009f000,len:2040 entry 0x4009f12c tcpip_task_hdlxxx : 3ffd45b8, prio:18,stack:2048 Guru Meditation Error of type StoreProhibited occurred on core 0. Exception was unhandled. Register dump: PC : 0x40081b59 PS : 0x00060031 A0 : 0x80081d29 A1 : 0x3ffc07a0 A2 : 0x3ffe1a40 A3 : 0x00000000 A4 : 0x00000000 A5 : 0x3ffc39d8 A6 : 0x00000000 A7 : 0xffffffff A8 : 0x3ffe1a40 A9 : 0x00000000 A10 : 0xffffffff A11 : 0x00000000 A12 : 0x800d1fc4 A13 : 0x3ffd37e0 A14 : 0xffffffff A15 : 0x00000000 SAR : 0x0000001b EXCCAUSE: 0x0000001d EXCVADDR: 0x00000018 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x00000000 Backtrace: 0x40081b59:0x3ffc07a0 0x40081d29:0x3ffc07e0 0x40081190:0x3ffc0800 ets Jun 8 2016 00:22:57 -
You should add which board (WiPy, LoPy or SiPy) the dumps come from and precisely which firmware version you're running, otherwise they can't be used for tracing the problem
@jmarcelino - good point, thanks I have added them.
