    Don't know why is giving an error
    2 Posts 2 Posters 60 Views 2 Watching
    • E Offline
      ecabanas
      Hi all
      I have this code to read some sensors (could be a goor guide for newbies like me)
      Now is working perfecte, but when I triying to add Sigfox the code returns an error:
      Code without Sigfox:
      import bme280_float as bme280
      from machine import Pin
      from machine import ADC
      from ds18x20 import DS18X20
      from onewire import OneWire
      # from network import Sigfox
      # import socket
      def read_bme280():
          # this script assumes the default connection of the I2C bus
          # On pycom devuces that is P9 = SDA, P10 = scl
          print('**************Reading BME280**************')
          # i2c = machine.I2C()
          # bme = bme280.BME280(i2c=i2c)
          # print(bme.read_compensated_data())
          # print(bme.dew_point)
          i2c = machine.I2C()
          Values= bme.values
          tempbme=res = ''.join(filter(lambda i: i.isdigit(), Values[0]))
          tempbme280=int(tempbme)/100
          print(tempbme280)
          pressbme=res = ''.join(filter(lambda i: i.isdigit(), Values[1]))
          pressbme280=int(pressbme)/100
          print(pressbme280)
          humbme=res = ''.join(filter(lambda i: i.isdigit(), Values[2]))
          humbme280=int(humbme)/100
          print(humbme280)
          print('**************End of Reading BME280**************')
      def read_analogs():
          print('**************Reading moisture **************')
          adc = machine.ADC()             # create an ADC object
          adc.init(bits=12)
          soilmoisture = adc.channel(pin='P13', attn = machine.ADC.ATTN_11DB)   # create an analog pin on P13, range 0..3.3V
          print('moisture raw: ')
          print (soilmoisture())
          print('**************End of Reading moisture **************')
          print('**************Reading Battery **************')
          adc = ADC()
          # Set calibration - see note above
          adc.vref(1100)
          # Check calibration by reading a known voltage
          adc_c = adc.channel(pin='P16', attn=ADC.ATTN_11DB)
          print('Battery raw: ')
          print(adc_c.voltage())
          print('**************End of Reading Battery **************')
      def read_ds18X20():
          print('**************Reading DS18X20 **************')
          #DS18B20 data line connected to pin P10
          ow = OneWire(Pin('P10'))
          temp = DS18X20(ow)
          print("Powermode = ", temp.powermode(Pin('P11')))
          roms = temp.scan()
          temp.resolution(roms[0], 9)
          print("Resolution", temp.resolution(roms[0]))
          temp.convert_temp()
          contador_DS18X20 = 0
          temp_Acc=0
          temp_moisture=0
          while contador_DS18X20 <5:
              time.sleep(1.5)
              for rom in roms:
                  print(temp.read_temp(rom), end=" ")
              print()
              temp.convert_temp()
              temp_Acc =(temp.read_temp(rom) + temp_Acc)
              temp_moisture=temp_Acc/5
              contador_DS18X20 +=1
              print (contador_DS18X20)
              print (temp_Acc)
              print (temp_moisture)
              print ('---------')
              print('**************End of Reading DS18X20 **************')
      read_bme280()
      read_analogs()
      read_ds18X20()
      And now when I want to import the libraries to activate Sigfox returns an error:
      # import pycom
      # import socket
      def read_bme280():
          i2c = machine.I2C()
          Values= bme.values
          print(tempbme280)
          print(pressbme280)
          print(humbme280)
      def read_analogs():
          adc.init(bits=12)
          adc = ADC()
          adc.vref(1100)
      def read_ds18X20():
          temp = DS18X20(ow)
          roms = temp.scan()
          temp.convert_temp()
          temp_Acc=0
          temp_moisture=0
              time.sleep(1.5)
              for rom in roms:
              print()
              temp.convert_temp()
              print (temp_Acc)
              print ('---------')
      read_bme280()
      read_analogs()
      read_ds18X20()
      # time.sleep(1)
      It crashes, any idea why? thank very very much
      Powermode =  0
        File "main.py", line 101, in <module>
        File "main.py", line 68, in read_ds18X20
      IndexError: list index out of range
      Pycom MicroPython 1.20.2.r1 [v1.11-a5aa0b8] on 2020-09-09; SiPy with ESP32
      Pybytes Version: 1.6.0
        claus @ecabanas
        @ecabanas Python almost tells you where the problem is. Check line 68, looks like your array "roms" is empty. Go back from there. Also, always try to reduce your example to a minimum example that fails (just a few lines of code), this increases the probability for someone to help you.
