    Don't understand fundamental concept of Pymakr and modules
    3 Posts 3 Posters 56 Views 3 Watching
      Patrick Keogh
      I wasn't sure whether to put this in Pymakr or just "Getting Started"...
      I know Python well, but despite reading lots of introductory documentation there is something fundamental that I don't understand. I have Atom and Pymakr running fine. I can load a Python module as main.py and it executes just fine. I can type Python statements to the ">>>" and they work fine too.
      My program will use MQTT, and so I found the module and I have it as umqtt.py. I copied it to .atom/packages/umqtt/umqtt.py
      I have a project that has three files:
      boot.py (empty)
      main.py (38 lines of code)
      lib/umtqq.py (205 lines of code)
      The first few lines of main.py are
      print("Init of main")
      pycom.rgbled(0xFF0000)  # Green
      from umqtt import MQTTClient
      from network import WLAN
      So I use Pymakr to
      • Format flash storage
      • With the project selected, Upload Project to Device
      Reading file status
      Failed to read project status, uploading all files
      Creating dir Garage
      Creating dir Garage/lib
      [1/3] Writing file Garage/boot.py (0kb)
      [2/3] Writing file Garage/lib/umqtt.py (6kb)
      [3/3] Writing file Garage/main.py (0kb)
      OKets Jun  8 2016 00:22:57
      rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8020,len:8
      load:0x3fff8028,len:2140
      ho 0 tail 12 room 4
      load:0x4009fa00,len:19760'''
      That all looks OK to me, but then if I select main.py and click Run I get
      Init of main
        File "<stdin>", line 7, in <module>
      ImportError: no module named 'umqtt'
      Pycom MicroPython 1.20.2.r1 [v1.11-a5aa0b8] on 2020-09-09; WiPy with ESP32
      Pybytes Version: 1.6.0
      So main.py runs and the LED is indeed red, but the import fails. So what am I not understanding about importing modules?
      • M Offline
        Manuel Ricardo Alfonso Sanchez @Patrick Keogh
        @Patrick-Keogh said in Don't understand fundamental concept of Pymakr and modules:
        Garage
        Hi. I suggest you to upload files directly in flash. As I seen in your upload sketch it appears a Garage folder and inside the lib folder and so on.
          p s
          This is a classic.
          You have to change your import from
          to
          from lib.umqtt import MQTTClient
          Thit will solve the problem.
          However, I would recommend creating an empty file called __init__.py inside your lib folder. This way you just need to make a reference to the package where your libraries are, like
          from directory.filename import Myclass
          This might be helpful if you need to import something from a directory one level up.
