Deploying release throws unhandled exception on FiPy device
  • I created a zip file of simple RGB led blinker test software, created a release for it and tried to deploy it through Pybytes. As soon as deployment is initiated in web interface, device will throw an unhandled exception. I tried this multiple times.
    Interestingly I did try OTA firmware update in device section, and that completed successfully.
    What could be the issue here? Unhandled exception doesn't seem correct, so this feels like a bug in the firmware.
    Firmware: 1.20.2.r2
    Pybytes: 1.6.1
    Initialized watchdog for WiFi and LTE connection with timeout 1260000 ms
    LTE connection established
    connect_lte with start_mqtt is now removed please call communication_protocol or start_mqtt directly
    Connected to MQTT mqtt.pybytes.pycom.io
    Pybytes connected successfully (using the built-in pybytes library)
    Pycom MicroPython 1.20.2.r2 [v1.11-3a7776d] on 2020-11-23; FiPy with ESP32
    Pybytes Version: 1.6.1
    >>> Unhandled exception in thread started by <bound_method>
      File "_msg_handl.py", line 259, in _io_thread_func
      File "_msg_handl.py", line 197, in _receive_packet
      File "_mqtt_core.py", line 398, in _recv_callback
      File "_mqtt_core.py", line 368, in _parse_publish
      File "_mqtt_core.py", line 341, in _notify_message
      File "_mqtt.py", line 91, in set_callback
      File "_pybytes_protocol.py", line 184, in __process_recv_message
      File "_pybytes_protocol.py", line 833, in deploy_new_release
      File "_pybytes_protocol.py", line 718, in update_files
      File "_flash_control_OTA.py", line 42, in update_file_content
    OSError: [Errno 19] ENODEV
  • Hi,
    Sorry I must have missed your topic last week,
    The ENODEV error occurs when the device is not available, for example like this:
    >>> open('/sd/file.py','w')
    >>> open('/flash/file.py','w')
    <io.TextIOWrapper 3f94f010>
    >>> open('/lib/file.py','w')
    Which is basically the operation where it stops working.
    When I try to write a file to the SD card or lib folder on root, which is not there, it will return the error. Similarly,
    >>>open('/flash/lib/file.py', 'w')
    OSError: [Errno 2] ENOENT
    Will give the error for NO ENTRY, as I did not create the lib folder in /flash/
    You are probably supposed to put the files inside a flash or lib folder? Check the pymakr online interface to see if it is correct. Let me know!
