    socket.sendto error:
    3 Posts 2 Posters 69 Views 2 Watching
    • I Offline
      Ibrahim Salim Omari
      greetings,
      when I run the following code:
      #!/usr/bin/python3
      ''' udp socket client Silver Moon '''
      import socket   #  for sockets
      import sys #  for exit
      # create dgram udp socket
      try:
          s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
      # except socket.error:
      except OSError as err:
          print('Failed to create socket')
          sys.exit()
      host = 'localhost'
      port = 8888
          msg = input('Enter message to send : ')
          try :
              # Set the whole string and convert encode the string to bytes
              s.sendto(str.encode(msg), (host, port))
              # receive data from client (data, addr)
              d = s.recvfrom(1024)
              reply = d[0]
              addr = d[1]
              print('Server reply : ' + str(bytes.decode(reply)))  # convert reply to string
          # except Exception as err:
              print('Error Code : ' + str(msg[0]) + ' Message ' + str(msg[1]))
              sys.exit()
      this line:
      throws the following error:
      ValueError: invalid arguments
      the line works on a full python environment. But it doesn't in micropython.
      Any suggestions?
      iomari
        It took me some time, but the issue is with 'localhost', the micropython expects an IP address there. Other than that, it should work fine once you are connected to a network
        • I Offline
          Ibrahim Salim Omari @Gijs
          @Gijs Thanks. It was the localhost. Working fine now with an ip address.
