    Error posting data to my server
    3 Posts 2 Posters 47 Views 2 Watching
    • E Offline
      ecabanas
      Hi
      I'm using this code to post a json to my server. In Arduino we use HTTP client using this variables:
      char server[] = "********.com";
      char path[] = "/api/v2/gprs";
      int port = 11880;
      In the request library I changed the default port 80 in HTTP to 11880
      urequest.py
      def request(method, url, data=None, json=None, headers={}, stream=None):
          try:
              proto, dummy, host, path = url.split("/", 3)
          except ValueError:
              proto, dummy, host = url.split("/", 2)
              path = ""
          if proto == "http:":
              port = 11880
          elif proto == "https:":
              import ussl
              port = 443
              raise ValueError("Unsupported protocol: " + proto)
      main.py
      import os
      import ujson
      import urequests
      from network import WLAN
      wlan = WLAN(mode=WLAN.STA)
      # Configure first UART bus to see the communication on the pc
      uart = machine.UART(0, 115200)
      # Configure second UART bus on pins P3(TX1) and P4(RX1)
      uart1 = UART(1, baudrate=115200) # 9600 baudrate also causes the same problem
      # Init WLAN
      try:
        wlan.connect(ssid="******", auth=(WLAN.WPA2, "*********"))
        while not wlan.isconnected():
          time.sleep_ms(50)
          print(wlan.ifconfig())
        print("WLAN connection on ...")
      except:
        print("[WLAN] try() (except). reset board.")
      data_set = {"dot":"gsm001","data":{"5":0,"6":999,"7":0,"14":3.0832,"31":0,"32":0,"33":0,"35":22,"38":300,"39":-50,"40":300,"42":300}}
      jsondump= ujson.dumps(data_set)
      urequests.request("POST","http://********.com/api/v2/gprs",data = jsondum, None, {"Content-Type": "application/json"},None).text
      but I got the following error:
      WiFi connection established
      MQTT ERROR! function got multiple values for argument 'user'
      ERROR! Could not connect to Pybytes!
        File "main.py", line 27, in <module>
      SyntaxError: non-keyword arg after keyword arg
      Pycom MicroPython 1.20.2.r2 [v1.11-3a7776d] on 2020-11-23; GPy with ESP32
      Any idea what I'm doing wrong? I'm a newbie in pycom code, sorry
      thank's
        jcaron @ecabanas
        @ecabanas If you don't use Pybytes you probably want to disable it with pycom.pybytes_on_boot(False) to avoid confusing messages.
        The issue is that you have a mix of arguments with explicit names (name =) and without in your call to urequests.request.
        Either use names for all args (method="POST", url="...", data=jsondum, json=None, headers={"Content-Type": "application/json"}, stream=None — in which case you can actually skip those where your argument matches the default) or don't use any and just respect the order (i.e. just remove data=).
        • E Offline
          ecabanas
          Hi @jcaron
          WOW!!! thanks now is working perfect!!!
          Thanks again!!!
