    MRAA and UPM Python3 use
    1 Posts 1 Posters 13 Views 1 Watching
      Jos Scheelen
      Hello, I will try to make the question mores specific. Any suggestion related to solve this issue is highly appreciated.
      This is the situation.
      This code works fine, MRAA only :
      #!/usr/bin/env python3
      import mraa
      board_type = mraa.getPlatformType()
      print (" Board type", board_type)
      board_name = mraa.getPlatformName()
      print (" Board name", board_name)
      mraa_version = mraa.getVersion()
      print (" MRAA Verson = ", mraa_version)
      for x in range(0,40):
      mraa_pin_name = mraa.getPinName (x)
      print (" Pin ", x, " name = ", mraa_pin_name)
      This code works also fine, MRAA and UPM :
      from time import sleep, localtime
      DIO = 8
      CLK = 7
      from upm import _pyupm_tm1637 as TM1637
      getVersion = TM1637.getVersion()
      print ("Version TM1637 = ",getVersion)
      This code works not, MRAA and UPM based on UPM examples included with the installation of UPM :
      This is the example python code
      I tried with and without the _ wto different responses.
      ./tm1637.py
      File "./tm1637.py", line 27, in <module>
      from upm import pyupm_tm1637 as tm1637
      ImportError: cannot import name 'pyupm_tm1637' from 'upm' (/usr/lib64/python3.8/site-packages/upm/init.py)
      ./tm1637.py
      File "./tm1637.py", line 62, in <module>
      main()
      File "./tm1637.py", line 37, in main
      The code used (based on the installedexamples during the UPM installation process.)
      from future import print_function
      import time, signal
      Two different tries ...
      from upm import -pyupm_tm1637 as tm1637
      def main():
      # Register exit handler for normal Ctrl+C exit
      def SIGINTHandler(signum, frame):
      raise SystemExit
      signal.signal(signal.SIGINT, SIGINTHandler)
      # Create a display object on pins 0 CLK and 1 DIO
      display = tm1637.TM1637(0, 1)
      dots = True
      # Get local time
      myTime = time.localtime(time.time())
      print(time.strftime("System time: %H:%M", myTime))
      print ("You can adjust your time zone by setting the TZ environment variable.")
      # Draw a box for 3 seconds using 7-segment encoding
      display.write(0x39, 0x09, 0x09, 0x0f)
      time.sleep(3)
      # Loop indefinitely
      	# Update and display time
      	timeString = time.strftime("%H%M", time.localtime(time.time()))
      	display.write(timeString)
      	# Toggle colon
      	display.setColon(dots)
      	dots = not dots
      	# Sleep for 1 s
      if name == 'main':
      main()
