    WiPy 1.0 Bricked, Red Light on even after factory reset
    resetbrickedfactorywipy 1help
    9 Posts 4 Posters 2.9k Views 4 Watching
    • F Offline
      Foennie Pybytes Beta
      I tried to upgrade the WiPy firmware as on the /gettingstarted instructions. Unfortunately, this made the WiPy unusable. When I start up the device, the red heartbeat light just stays on. Even if I do a factory reset (3.3V to Pin28) the heartbeat light flashes for 3 seconds, then faster for another 3 seconds, then even faster for another 1.5 seconds. Then the static red heartbeat light goes on again. Ive searched forums and asked around. My Dealer said I should contact you. Please can you help me. I was going to prototype a new alarm system (specifically for South African Homes) using this device, but with its failure I had to switch over to Raspberry Pi.
        josua @Foennie
        @Foennie Hi, I have exactly the same problem with my SiPy after upgrading with the latest firmware.. Did you solve it?
          jmarcelino @josua
          @josua
          The SiPy is a very different device, have you tried resetting it, for example by pressing the reset button?
          • F Offline
            I have been unable to solve this. I had to take it back to the supplier. After 2 weeks they told me that they too could not fix it, so they ended up replacing it for me. I think this device is soooo dainty. Its definitely not a robust industrial grade solution. Mostly home and Project use.
              livius @Foennie
              @Foennie
              my few wipy work near continously near half of year
              maybe you have bad one
                josua @jmarcelino
                @jmarcelino Yes I tried resetting it and I tried to boot in safe mode. Nothing changes... The red light stays on. I also tried to connect to SiPy via Putty COM and what I see is only the black terminal screen. And last, when my SiPy is on, there is no Wi-Fi connection to it.
                J J 2 Replies Last reply Reply Quote 0
                  josua @josua
                  @josua @josua
                  Nice, it works now. I tried to upgrade it once again doing this steps and it works:
                  Disconnect your device from the PC.
                  Connect wire G23+GND using a jumper cable.
                  Connect the board to the USB.
                  Run the upgrader
                  Remove the G23+GND wire.
                  Reboot the device (button or powercycle)
                    jmarcelino @josua
                      jmarcelino @josua
                      @josua
                      Glad you got it working by doing the firmware upgrade procedure again
