VBatt with CayenneLPP?
  • I'm trying to get the vbatt values from my Pysense with a FiPy to send the values out via Lora using the CayenneLPP, but the cayenne library has no references to vbatt. I have no idea how to go about adding the right code there. Any ideas??
    In main.py
    print(
            'Acceleration:', li.acceleration(),
            ', Roll:', li.roll(),
            ', Pitch:', li.pitch(),
            ', Light:', lt.light(),
            ', Humidity:', si.humidity(),
            ', Temperature:', si.temperature(),
            ', Battery Voltage: ', py.read_battery_voltage()
            ## ADD DATA TO CAYENNELPP
            #lpp.add_accelerometer(1, li.acceleration()[0], li.acceleration()[1], li.acceleration()[2])
            #lpp.add_gryrometer(1, li.roll(), li.pitch(), 0)
            #lpp.add_luminosity(1, lt.light()[0])
            #lpp.add_luminosity(2, lt.light()[1])
            #lpp.add_relative_humidity(1, si.humidity())
            lpp.add_temperature(1, si.temperature())
            lpp.add_vbatt(1, py.read_battery_voltage())
    Error:
    AttributeError: 'CayenneLPP' object has no attribute 'add_vbatt'
    CayenneLPP.py
    Source: https://github.com/simonqbs/cayennelpp-python
    import struct
    import math
    LPP_DIGITAL_INPUT = 0         # 1 byte
    LPP_DIGITAL_OUTPUT = 1        # 1 byte
    LPP_ANALOG_INPUT = 2          # 2 bytes, 0.01 signed
    LPP_ANALOG_OUTPUT = 3         # 2 bytes, 0.01 signed
    LPP_LUMINOSITY = 101          # 2 bytes, 1 lux unsigned
    LPP_PRESENCE = 102            # 1 byte, 1
    LPP_TEMPERATURE = 103         # 2 bytes, 0.1°C signed
    LPP_RELATIVE_HUMIDITY = 104   # 1 byte, 0.5% unsigned
    LPP_ACCELEROMETER = 113       # 2 bytes per axis, 0.001G
    LPP_BAROMETRIC_PRESSURE = 115 # 2 bytes 0.1 hPa Unsigned
    LPP_GYROMETER = 134           # 2 bytes per axis, 0.01 °/s
    LPP_GPS = 136                 # 3 byte lon/lat 0.0001 °, 3 bytes alt 0.01 meter
    # Data ID + Data Type + Data Size
    LPP_DIGITAL_INPUT_SIZE = 3       # 1 byte
    LPP_DIGITAL_OUTPUT_SIZE = 3      # 1 byte
    LPP_ANALOG_INPUT_SIZE = 4        # 2 bytes, 0.01 signed
    LPP_ANALOG_OUTPUT_SIZE = 4       # 2 bytes, 0.01 signed
    LPP_LUMINOSITY_SIZE = 4          # 2 bytes, 1 lux unsigned
    LPP_PRESENCE_SIZE = 3            # 1 byte, 1
    LPP_TEMPERATURE_SIZE = 4         # 2 bytes, 0.1°C signed
    LPP_RELATIVE_HUMIDITY_SIZE = 3   # 1 byte, 0.5% unsigned
    LPP_ACCELEROMETER_SIZE = 8       # 2 bytes per axis, 0.001G
    LPP_BAROMETRIC_PRESSURE_SIZE = 4 # 2 bytes 0.1 hPa Unsigned
    LPP_GYROMETER_SIZE = 8           # 2 bytes per axis, 0.01 °/s
    LPP_GPS_SIZE = 11                # 3 byte lon/lat 0.0001 °, 3 bytes alt 0.01 meter
    class CayenneLPP:
        def __init__(self):
            self.buffer = bytearray()
        def get_buffer(self):
            return self.buffer
        def reset(self):
        def get_size(self):
            return len(self.buffer)
        def add_temperature(self, channel, value):
            val = math.floor(value * 10);
            self.buffer.extend(struct.pack('b', channel))
            self.buffer.extend(struct.pack('b', LPP_TEMPERATURE))
            self.buffer.extend(struct.pack('b', val >> 8))
            self.buffer.extend(struct.pack('b', val))
        def add_relative_humidity(self, channel, value):
            val = math.floor(value * 2)
            self.buffer.extend(struct.pack('b', LPP_RELATIVE_HUMIDITY))
        def add_digital_input(self, channel, value):
            self.buffer.extend(struct.pack('b', LPP_DIGITAL_INPUT))
            self.buffer.extend(struct.pack('b', value))
        def add_digital_output(self, channel, value):
            self.buffer.extend(struct.pack('b', LPP_DIGITAL_OUTPUT))
        def add_analog_input(self, channel, value):
            val = math.floor(value * 100)
            self.buffer.extend(struct.pack('b', LPP_ANALOG_INPUT))
        def add_analog_output(self, channel, value):
            self.buffer.extend(struct.pack('b', LPP_ANALOG_OUTPUT))
        def add_luminosity(self, channel, value):
            self.buffer.extend(struct.pack('b', LPP_LUMINOSITY))
            self.buffer.extend(struct.pack('b', value >> 8))
        def add_presence(self, channel, value):
            self.buffer.extend(struct.pack('b', LPP_PRESENCE))
        def add_accelerometer(self, channel, x, y, z):
            vx = math.floor(x * 1000)
            vy = math.floor(y * 1000)
            vz = math.floor(z * 1000)
            self.buffer.extend(struct.pack('b', LPP_ACCELEROMETER))
            self.buffer.extend(struct.pack('b', vx >> 8))
            self.buffer.extend(struct.pack('b', vx))
            self.buffer.extend(struct.pack('b', vy >> 8))
            self.buffer.extend(struct.pack('b', vy))
            self.buffer.extend(struct.pack('b', vz >> 8))
            self.buffer.extend(struct.pack('b', vz))
        def add_barometric_pressure(self, channel, value):
            self.buffer.extend(struct.pack('b', LPP_BAROMETRIC_PRESSURE))
        def add_gryrometer(self, channel, x, y, z):
            vx = math.floor(x * 100)
            vy = math.floor(y * 100)
            vz = math.floor(z * 100)
            self.buffer.extend(struct.pack('b', LPP_GYROMETER))
        def add_gps(self, channel, latitude, longitude, meters):
            lat = math.floor(latitude * 10000)
            lon = math.floor(longitude * 10000)
            alt = math.floor(meters * 100)
            self.buffer.extend(struct.pack('b', LPP_GPS))
            self.buffer.extend(struct.pack('b', lat >> 16))
            self.buffer.extend(struct.pack('b', lat >> 8))
            self.buffer.extend(struct.pack('b', lat))
            self.buffer.extend(struct.pack('b', lon >> 16))
            self.buffer.extend(struct.pack('b', lon >> 8))
            self.buffer.extend(struct.pack('b', lon))
            self.buffer.extend(struct.pack('b', alt >> 16))
            self.buffer.extend(struct.pack('b', alt >> 8))
            self.buffer.extend(struct.pack('b', alt))
  • It's up to you..both can do the job.
    a) lpp.add_analog_input(1, py.read_battery_voltage())
    or
    b) lpp.add_analog_output(1, py.read_battery_voltage())
