    LoPy4 hangs on receive loop while in c-clas
    lopy4c classreceivehang
    3 Posts 2 Posters 71 Views 2 Watching
      Jamie
          try:
              rx = s.recv(64)
              if rx:
                  rxStr = str(rx).split("'")
                  s.send("Sw#," + rxStr[1])
                  index = int(rxStr[1])
                  i2c.writeto(56, 255-index)
                  print("swSet = ", index)
                  wdt.feed()
          except Exception as error:
              print(error)
              s.send(str(error))
          time.sleep_ms(500)
      Greetings,
      I'm hoping someone might see a problem in this receive loop. The device is in c class mode when it reaches this code and then it waits to receives data that is sent every minute. The data is a incrementing number and the number is echoed back thru the gateway and into a database for testing. The problem is that the devices will work fine for awhile and then hang until the WDT resets. I have five devices working side by side with the message coming in to each device spaced one second apart and they will all hang but how offend differs between devices. I also miss messages but that does not concern me as much as the 5 to 7 minutes it takes to restart the device. The i2c chip is a I expander running switches. Do I need to do something as simple as adding a time.sleep() somewhere?
        jcaron @Jamie
        @Jamie you should probably add a few logs in order to determine exactly where it hangs (receiving or sending over LoRa, sending over I2C).
        Is the socket set to blocking or non-blocking?
          Jamie
              rx = s.recv(64)
              time.sleep_ms(10)
              if rx:
                  time.sleep_ms(10)
                  try:
                      print("i2c",error)
                  startTime = time.ticks_ms()
                  s.setblocking(True)
                  time.sleep_ms(10)
                      try:
                          s.send("ack")
                          print("send ",error)
                  time.sleep_ms(10)
                  s.setblocking(False)
                  print(time.ticks_ms()-startTime)
                  wdt.feed()
          @jcaron thanks for your response. The problem is in the s.send(). I added the setblocking() statements around the statement along with putting it in its own try/except but they are still resetting at least 12-16 times a day. Is there any thing else you think I should check? Gateway setting? I'm using a Multitech Conduit gateway that's running node-red.
          Thanks again
