    OSError: [Errno 90] EMSGSIZE
    5 Posts 3 Posters 53 Views 3 Watching
    • Z Offline
      Zino Henderickx
      Hi everyone, I am working on a project.
      When I send a bytestring to LoRa I get a error because my bytestring is to long.
      Does someone know how I can resolve this problem?
      from machine import Pin
      from network import LoRa
      import binascii
      import array
      from machine import PWM
      ############### LoRa Connectie ###############
      lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)
      app_eui = binascii.unhexlify('70B3D57ED003B935')
      app_key = binascii.unhexlify('D0258B34705B17B2DD2C87CA07CA5D68')
      # wait until the module has joined the network
      while not lora.has_joined():
          time.sleep(2.5)
          print('Not joined yet...')
      print('Network joined!')
      ############### Weightsensor ###############
      def main():
              adc = machine.ADC()             # create an ADC object
              apin = adc.channel(pin='P16')   # create an analog pin on P16
              val = apin()
              low = apin()                    # read an analog value
              high = apin()                    # read an analog value
              if val < 20:
                  print(val)
                  print("Weight is good")
                  binaryString = bin(low)
                  print(binaryString)
                  time.sleep(2.5)
              if val > 20:
                  print(val)
                  print("Weight is to high")
                  binaryString = bin(high)
                  print(binaryString)
                  time.sleep(2.5)
                  # 50% duty cycle at 38kHz.
                  pwm = PWM(3, frequency=78000)  # use PWM timer 0, with a frequency of 5KHz
                  # create pwm channel on pin P12 with a duty cycle of 50%
                  pwm_c = pwm.channel(0, pin='P20', duty_cycle=1.0)
                  pwm_c.duty_cycle(0.3) # change the duty cycle to 30%
              s.setblocking(False)
              s.send(bytes(high))
      if __name__ == "__main__":
          main()
      robert-hhR J 3 Replies Last reply Reply Quote 0
        robert-hh @Zino Henderickx
        @Zino-Henderickx The pyaload size of a Lora message depends on the spreading factor, and ranges e.g. for EU868 between 51 and 222 bytes, for US915 between 11 and 222 bytes . How long is the byte strings you attempt to send, and which spreading factor are you using?
          jcaron @Zino Henderickx
          @Zino-Henderickx you should probably use ustruct to pack your value rather than bytes directly on a float. Don’t have a device at hand to test, but I suspect the latter sends a text version of the float, which can be quite long.
          It shouldn’t be a problem at DR5 though. Log the size and contents of your payload, it should be informative.
          Z 1 Reply Last reply Reply Quote 1
            @Zino-Henderickx Just spotted the reason:
            the line:
            s.send(bytes(high))
            sends bytes(high), which is a bytearray with the number of bytes, which is given by the value of high. So if high is 1000, it will create a 1000 bytes long object.
            You may use str(high).endcode(), or use struct.pack() as @jcaron mentioned.
            • Z Offline
              Zino Henderickx @jcaron
              @jcaron Yes I will try that. Thanks for the advice!
