    How to receive data from UDP socket (over WiFi)
    6 Posts 2 Posters 182 Views 2 Watching
    • N Offline
      nadvorvo
      Hi everyone,
      I am trying to send UDP packet using GPy. For testing I am using service QOTD (djxmmx.net).
      On my desktop python the code if functional, on GPy no data received.
      Thank you in advance for your assistance.
      Regards, Vojtech
      code snipet from GPy
      >>> uos.uname()
      (sysname='GPy', nodename='GPy', release='1.20.2.r3', version='v1.11-d945d33ee on 2020-03-08', machine='GPy with ESP32',pybytes='1.3.1')
      >>> wifi1.wlan.isconnected()
      True
      >>> import socket
      >>> UDP_IP = "68.228.188.226"
      >>> UDP_PORT = 17
      >>> MESSAGE = b''
      >>> s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM, socket.IPPROTO_UDP)
      >>> s.settimeout(5)
      >>> s.sendto(MESSAGE, (UDP_IP, UDP_PORT))
      0
      >>> data, address = s.recvfrom(1024)
      TimeoutError: timed out
      when do same from my desktop the code is successful:
      >>> import socket
      >>> UDP_PORT = 17
      >>> MESSAGE = b''
      >>> s.settimeout(5)
      0
      >>> print(data.decode())
      "The secret of being miserable is to have leisure to bother about whether
       you are happy or not.  The cure for it is occupation."
       George Bernard Shaw (1856-1950)
        robert-hh @nadvorvo
        @nadvorvo Could it be a setting of your internet router?
        • N Offline
          nadvorvo
          Hi @robert-hh,
          Thank you for your reply. I am connected to same wifi network from both devices (desktop notebook, GPy). Router settings should not be problem.
            robert-hh @nadvorvo
            @nadvorvo So I could replicate your problem. Interestingly it also exists in different flavors on other micropython (non-pycom) variants and devices.
            With Pycom MicroPython the receive fails.
            On ESP32 and Winnermicro W600 ports the send returns a timeout error, but the following receive succeeds.
            On ESP8266 and Pyboard UD is not supported.
            Big mess.
            BUT: if you do not send an empty message, but for instance a single space, it works. So there is a problem dealing with an empty packet.
              robert-hh @nadvorvo
              @nadvorvo Update: on all devices this modified code works:
              UDP_PORT = 17
              MESSAGE = b' '
              s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
              s.settimeout(5)
              print(s.sendto(MESSAGE, (UDP_IP, UDP_PORT)))
              N 1 Reply Last reply Reply Quote 2
              • N Offline
                nadvorvo @robert-hh
                Hi @robert-hh,
                I really appreciate the support you’ve given me. Thank you.
                Also functional on my side.
                Regards, Vojtech
