    MQTT library conflict with pybytes
    5 Posts 3 Posters 97 Views 3 Watching
      Laurens van Raay
      Re: Pybytes: MQTT ERROR! function got multiple values for argument 'user'
      Any updates on the MQTT error?
      Seems to be a conflict between the use of pybytes and the MQTT library.
        Laurens van Raay
        If anyone else has the same problem, here is a solution.
        Problem:
        Pybytes does not start when the mqtt.py library is installed on the device.
        The device throws the following error during boot:
        WiFi connection established
        MQTT Protocol
        ERROR! Could not connect to Pybytes!
        This occurs during boot, so even if main.py and boot.py on the device are empty files. Probably pybytes is using the MQTTClient class in the mqtt library in the lib folder when it shouldn't.
        Rename the class in mqtt.py:
        class MQTTClient_lib:
        Rewrite your code for the name change or use an alias where the library is included to keep the source unmodified:
        from mqtt import MQTTClient_lib as MQTTClient
        This solved the issue for me.
          I really like your solution,
          If it is okay with you, I'll post it to the docs!
            Laurens van Raay @Gijs
            @Gijs
            Hi Gijs,
            Sure, that's okay with me.
              Clyde Bess
              I will also give this a try thanks for sharing!
              I am new to python and micopython, if stuck in such a problem for days...
              I changed firmwares over and over. Even got me an Windows PC (Mac User..)
              Again - thanks for sharing :)
