Boot.py conf lost
I've a strange behavior with the boot.py file. At the boot time, boot.py is executed and connect correctly to my wifi network and returns the IP address, but when I get the REPL prompt, the configuration is lost, isconnected returns false. If I run manually the script, then the connection is fine.
Thanks for your help
Laurent
Scanning for known wifi nets ...... Connected to XXXXXXX with IP address:192.168.1.53 Smart Provisioning started in the background See https://docs.pycom.io/smart for details Pycom MicroPython 1.20.2.r4 [v1.11-ffb0e1c] on 2021-01-12; LoPy4 with ESP32 Pybytes Version: 1.6.1 Type "help()" for more information. >>> wl.isconnected() False >>> Running C:\.........\boot.py >>> >>> Connected to XXXXXXXX with IP address: .isconnected()192.168.1.53 > Pycom MicroPython 1.20.2.r4 [v1.11-ffb0e1c] on 2021-01-12; LoPy4 with ESP32 Pybytes Version: 1.6.1 Type "help()" for more information. >>> >>> wl.isconnected() True >>> -
@Laurent-Toutain how long does your boot script for the connection to get established. That may take a few seconds.
Hi Robert,
I takes few seconds, in both cases it works, I got the IP address, but when boot.py is started automatically, I lose the information. Note the variable are available from REPL, I can manipulate wl, but the connection is lost. When i start manually it works. Looks like something after the boot.py reset the connection. I don't know what is Smart Provisionning started in the background means.
Laurent
@Laurent-Toutain Smart provisioning is the pybytes stuff, which indeed mangles with the communication interfaces. If you do not use pybytes, switch it off.
pycom.pybytes_on_boot(False).If that does not work, create a file on your device called pybytes_config.json and the content:
{"pybytes_autostart": false}
