    Error in the PyScan Pinout document
    21 Posts 3 Posters 110 Views 3 Watching
      robert-hh
      @gijs The pinout for the 10 pin connector below the development module is wrong. It is show in the upper right edge of the pinout page. The fault: The two rows are swapped. E.g. the square shaped pin is actually GND, and so on.
        gael cobert @robert-hh
        @robert-hh
        i think it's ok like this
        https://drive.google.com/file/d/12MmpMB4iqi4rWhJgjqHBV4_RT4JlCPYv/view?usp=sharing
        white cable is in P10
        photo of paper ink cable
        https://drive.google.com/file/d/12YH-9H6p9ER9C8j6_WI0op5xJrPmFzqv/view?usp=sharing
        no sign of life ...
          robert-hh @gael cobert
          @gael-cobert Using my Multimeter I see that the white cable is actually at P11. The pinout drawing is wrong. The next pin to the left is P8. So use that one for the moment. P8 an dP4 are used for the SD card, but as long as you do not use it, it's OK.
          By chance I had a Waveshare 4in2 epaper display here, and it works with the sample code.
            @robert-hh
            no change, photo of the white cable to pin P8
            is it right ?
            https://drive.google.com/file/d/12bptWVKfvO_Y1f_0ghyce_tIOygcBiVy/view?usp=sharing
            i changed the code too
            @robert-hh
            yes
            	Example for 4.2 inch black & white Waveshare E-ink screen
            	Run on ESP32
            import epaper4in2
            from machine import Pin, SPI
            # SPIV on ESP32
            rst = Pin('P8')
            dc = Pin('P10')
            busy = Pin('P15')
            cs = Pin('P4')
            clk = Pin('P9')
            mosi = Pin('P19')
            spi = SPI(0, mode=SPI.MASTER, baudrate=2000000, polarity=0, phase=0, pins=(clk, mosi, None))
            e = epaper4in2.EPD(spi,cs , dc, rst, busy)
            e.init()
            w = 400
            h = 300
            x = 0
            y = 0
            # use a frame buffer
            # 400 * 300 / 8 = 15000 - thats a lot of pixels
            import framebuf
            buf = bytearray(w * h // 8)
            fb = framebuf.FrameBuffer(buf, w, h, framebuf.MONO_HLSB)
            black = 0
            white = 1
            fb.fill(white)
            print('print hello world')
            fb.fill(white)
            fb.text('Hello World',30,0,black)
            #fb.pixel(30, 10, black)
            #fb.hline(30, 30, 10, black)
            #fb.vline(30, 50, 10, black)
            #fb.line(30, 70, 40, 80, black)
            #fb.rect(30, 90, 10, 10, black)
            #fb.fill_rect(30, 110, 10, 10, black)
            #for row in range(0,36):
            #	fb.text(str(row),0,row*8,black)
            #fb.text('Line 36',0,288,black)
            e.display_frame(buf)
              @gael-cobert Yes. That is P8. Did you change your script accordingly?
                @robert-hh
                yes
                	Run on ESP32
                import epaper4in2
                # SPIV on ESP32
                rst = Pin('P8')
                dc = Pin('P10')
                busy = Pin('P15')
                cs = Pin('P4')
                clk = Pin('P9')
                mosi = Pin('P19')
                e.init()
                w = 400
                h = 300
                x = 0
                y = 0
                import framebuf
                black = 0
                white = 1
                fb.fill(white)
                fb.fill(white)
                  @gael-cobert I made a test with the static CS, and it did NOT work. So you have to connect cs. That's a little bit surprising, but .. You could try to use that P11 pin on the connector, or solder in another row of pins to get access to p4 and p10.
                    @robert-hh said in Error in the PyScan Pinout document:
                    CS
                    i put CS in P11
                    https://drive.google.com/file/d/12chEnjlWTnu94V6AZnhyeMdt583pmbWF/view?usp=sharing
                    and changed the code
                    import epaper4in2
                    # SPIV on ESP32
                    rst = Pin('P8')
                    dc = Pin('P10')
                    busy = Pin('P15')
                    cs = Pin('P11')
                    clk = Pin('P9')
                    mosi = Pin('P19')
                    e.init()
                    w = 400
                    h = 300
                    x = 0
                    y = 0
                    import framebuf
                    black = 0
                    white = 1
                    fb.fill(white)
                    fb.fill(white)
                      @gael-cobert Did it work? I'm not sure about using pins on the pyscan. Most of them have multiple labels, and when they are driven by the pyscan itself, they may not be usable.
                      Your small test script works here.
                        @robert-hh no it don't works :p
                        i don't know what to do ...
                          @gael-cobert Just give it a break. The connector where you have P11 now, is labeled as camera connector. As long as the camera is not used, all pins should be available. So let's focus on that, but not today. I will try to use the pyscan for that test tomorrow. At the moment, I use a simple expansion board.
                            @robert-hh ok thank you so much for your help :) i learned a lot of things indeed. See you tomorrow.
                              @gael-cobert Could not give it a rest, so I made a shot. This setting worked, all on the camera connector:
                              import epaper4in2
                              # SPIV on ESP32
                              sck = "P9"
                              miso = None
                              mosi = "P10"
                              dc = Pin("P3", Pin.OUT)
                              cs = Pin("P19", Pin.OUT)
                              rst = Pin("P11", Pin.OUT, value=1)
                              busy = Pin("P15", Pin.IN)
                              spi = SPI(0, baudrate=20000000, polarity=0, phase=0, pins=(sck, mosi, None))
                              e = epaper4in2.EPD(spi, cs, dc, rst, busy)
                              e.init()
                              w = 400
                              h = 300
                              x = 0
                              y = 0
                              import framebuf
                              black = 0
                              white = 1
                              fb.fill(white)
                              fb.fill(white)
                              The only problem that I had was the USB of the pyscan. I never used it before, and so the driver needed am update. I skipped that and connected with telnet.
                              G 2 Replies Last reply Reply Quote 0
                                sck = "P9"
                                miso = None
                                mosi = "P10"
                                did you try it with a piscan ? i changed my code with your example but not change ... i changed P8 to P11
                                I changed other pin
                                https://drive.google.com/file/d/12dhAIFz4ND_cvRy4eSzi3o79BKnx_9EB/view?usp=sharing
                                  @gael-cobert Yes. I used Pyscan for that. The same 0.7 version that you have. with long male/male adapter pins.
                                  If that does not work, the problem may be somewhere else.
                                    @robert-hh P11 is to the left of P13 ?
                                    https://drive.google.com/file/d/12uRecBvZEub8N-LTEvIxTz0T2M0FdGH_/view?usp=sharing
                                    can you give me a photo of your board ?
                                      import epaper4in2
                                      SPIV on ESP32
                                      sck = "P9"
                                      miso = None
                                      mosi = "P10"
                                      e.init()
                                      w = 400
                                      h = 300
                                      x = 0
                                      y = 0
                                      use a frame buffer
                                      import framebuf
                                      black = 0
                                      white = 1
                                      fb.fill(white)
                                      fb.fill(white)
                                      it works !!!!!!!!
                                        @gael-cobert Wonderful. Although the display update times are pretty long. So it's more suited for signs.
                                          @robert-hh yes do you know why it's so long ? ( around 3 sec )
                                          i have another question, i am using atom IDE, i want to use the NFC scan, but sometimes it stop, if i click "run selected files"
                                          if i transfer main.py file via FTP it don't seem to execute when the board start, it's a little bit strange
                                          import epaper4in2
                                          # NFC
                                          from pyscan import Pyscan
                                          from MFRC630 import MFRC630
                                          from LIS2HH12 import LIS2HH12
                                          from LTR329ALS01 import LTR329ALS01
                                          import binascii
                                          import _thread
                                          ttf_dir = 'ttf'
                                          # var NFC
                                          # This is the default key for an unencrypted MiFare card
                                          DEBUG = True  # change to True to see debug messages
                                          VALID_CARDS = [[0x43, 0x95, 0xDD, 0xF8],
                                                         [0x43, 0x95, 0xDD, 0xF9],
                                                         [0x8C, 0x43, 0x00, 0x5C],
                                                         [0x46, 0x5A, 0xEB, 0x7D, 0x8A, 0x08, 0x04]]
                                          py = Pyscan()
                                          nfc = MFRC630(py)
                                          lt = LTR329ALS01(py)
                                          li = LIS2HH12(py)
                                          RGB_BRIGHTNESS = 0x8
                                          RGB_RED = (RGB_BRIGHTNESS << 16)
                                          RGB_GREEN = (RGB_BRIGHTNESS << 8)
                                          RGB_BLUE = (RGB_BRIGHTNESS)
                                          counter = 0
                                          # SPIV on ESP32
                                          sck = "P9"
                                          miso = None
                                          mosi = "P10"
                                          e.init()
                                          w = 400
                                          h = 300
                                          x = 0
                                          y = 0
                                          import framebuf
                                          black = 0
                                          white = 1
                                          fb.fill(white)
                                          fb.fill(white)
                                          fb.text('bienvenue sur le système secureangel',30,0,black)
                                          # Make sure heartbeat is disabled before setting RGB LED
                                          # Initialise the MFRC630 with some settings
                                          nfc.mfrc630_cmd_init()
                                          def check_uid(uid, len):
                                              return VALID_CARDS.count(uid[:len])
                                          def print_debug(msg):
                                              if DEBUG:
                                                  print(msg)
                                          def send_sensor_data(name, timeout):
                                              while(True):
                                                  print(lt.light())
                                                  print(li.acceleration())
                                                  time.sleep(timeout)
                                          def discovery_loop(nfc, id):
                                                  # Send REQA for ISO14443A card type
                                                  print_debug('Sending REQA for ISO14443A card type...')
                                                  atqa = nfc.mfrc630_iso14443a_WUPA_REQA(nfc.MFRC630_ISO14443_CMD_REQA)
                                                  print_debug('Response: {}'.format(atqa))
                                                  if (atqa != 0):
                                                      # A card has been detected, read UID
                                                      print_debug('A card has been detected, read UID...')
                                                      uid = bytearray(10)
                                                      uid_len = nfc.mfrc630_iso14443a_select(uid)
                                                      print_debug('UID has length: {}'.format(uid_len))
                                                      if (uid_len > 0):
                                                          s =  binascii.hexlify(uid[:uid_len],' ').upper()
                                                          card_id = ("{:02X}"*len(s)).format(*s)
                                                          print_debug('card_id : -> {} <-'.format(card_id))
                                                          tst = s.decode("utf-8")
                                                          print_debug('tst : {} <-'.format(tst))
                                                          if(tst == "8C 43 00 5C") :
                                                              print_debug('hello gael')
                                                              fb.fill(white)
                                                              fb.text('Hello Gaël ! :)',30,80,black)
                                                          print_debug('Checking if card with UID: [{:s}] is listed in VALID_CARDS...'.format(binascii.hexlify(uid[:uid_len],' ').upper()))
                                                          if (check_uid(list(uid), uid_len)) > 0:
                                                              print_debug('Card is listed, turn LED green')
                                                              pycom.rgbled(RGB_GREEN)
                                                              print_debug('Card is not listed, turn LED red')
                                                              pycom.rgbled(RGB_RED)
                                                              fb.fill(white)
                                                              fb.text('carte introuvable :p',30,0,black)
                                                      # No card detected
                                                      #print_debug('Did not detect any card...')
                                                      pycom.rgbled(RGB_BLUE)
                                                  nfc.mfrc630_cmd_reset()
                                                  time.sleep(.5)
                                          # This is the start of our main execution... start the thread
                                          _thread.start_new_thread(discovery_loop, (nfc, 0))
                                          _thread.start_new_thread(send_sensor_data, ('Thread 2', 10))
                                            @gael-cobert I cannot tell anything about the Pycom IDE with either Atom or VSCode. The seem to fail constantly.
                                            I prefer to use primitive tools, like picocom | putty | beagle term for REPL, and plain ftp | filezilla or in the absence of wifi pyboard.py + mpr.py for file transfer.
                                            • 1
                                            • 2
                                            • 2 / 2
