    Pymakr error on VSCode
    10 Posts 4 Posters 199 Views 4 Watching
      Tarun Nigam
      Hi , I am facing error with pymakr on VScode, below is the detail, I am working on Rpi4 debian OS
      VS code
      Version: 1.51.1
      Commit: e5a624b788d92b8d34d1392e4c4d9789406efe8f
      Date: 2020-11-10T23:30:36.006Z
      Electron: 9.3.3
      Chrome: 83.0.4103.122
      Node.js: 12.14.1
      V8: 8.3.110.13-electron.0
      OS: Linux arm 5.4.51-v7l+
      Pymakr version
      Version:1.1.11
      Error:There was an error with your serialport module, Pymakr will likely not work properly. Please try to install again or report an issue on our github (see developer console for details)
      I am attaching the log from VS code, please help solve the issue. As I am beginner will request if youn can provide step wise process.
      Error Log as Below:
      /usr/share/code/resources/app/out/vs/workbench/workbench.desktop.main.js:5411 Extension 'ms-toolsai.jupyter cannot use PROPOSED API (must started out of dev or enabled via --enable-proposed-api)
      updateEnableProposedApi @ /usr/share/code/resources/app/out/vs/workbench/workbench.desktop.main.js:5411
      /usr/share/code/resources/app/out/vs/workbench/workbench.desktop.main.js:304 [Extension Host] Error while loading serialport library
      /usr/share/code/resources/app/out/vs/workbench/workbench.desktop.main.js:304 [Extension Host] Error: Could not locate the bindings file. Tried: → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/build/bindings.node → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/build/Debug/bindings.node → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/build/Release/bindings.node → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/out/Debug/bindings.node → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/Debug/bindings.node → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/out/Release/bindings.node → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/Release/bindings.node → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/build/default/bindings.node → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/compiled/12.14.1/linux/arm/bindings.node → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/lib/binding/node-v80-linux-arm/bindings.node at bindings (/home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/bindings/bindings.js:126:9) at Object.<anonymous> (/home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module.i._compile (/usr/share/code/resources/app/out/vs/loader.js:17:571) at Object.Module._extensions..js (internal/modules/cjs/loader.js:1051:10) at Module.load (internal/modules/cjs/loader.js:862:32) at Module._load (internal/modules/cjs/loader.js:774:14) at Function.Module._load (electron/js2c/asar.js:769:28) at Function.t._load (/usr/share/code/resources/app/out/vs/workbench/services/extensions/node/extensionHostProcess.js:1064:776) at Function.i._load (/usr/share/code/resources/app/out/vs/workbench/services/extensions/node/extensionHostProcess.js:1034:665) at Function.n._load (/usr/share/code/resources/app/out/vs/workbench/services/extensions/node/extensionHostProcess.js:1030:844) at Module.require (internal/modules/cjs/loader.js:899:19) at r (/usr/share/code/resources/app/out/vs/loader.js:17:346) at Object.<anonymous> (/home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/lib/index.js:14:22) at Module.i._compile (/usr/share/code/resources/app/out/vs/loader.js:17:571) at Object.Module._extensions..js (internal/modules/cjs/loader.js:1051:10) at Module.load (internal/modules/cjs/loader.js:862:32) at Module._load (internal/modules/cjs/loader.js:774:14) at Function.Module._load (electron/js2c/asar.js:769:28) at Function.t._load (/usr/share/code/resources/app/out/vs/workbench/services/extensions/node/extensionHostProcess.js:1064:776) at Function.i._load (/usr/share/code/resources/app/out/vs/workbench/services/extensions/node/extensionHostProcess.js:1034:665) at Function.n._load (/usr/share/code/resources/app/out/vs/workbench/services/extensions/node/extensionHostProcess.js:1030:844) at Module.require (internal/modules/cjs/loader.js:899:19) at r (/usr/share/code/resources/app/out/vs/loader.js:17:346) at Object.<anonymous> (/home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/serialport/lib/index.js:2:17) at Module.i._compile (/usr/share/code/resources/app/out/vs/loader.js:17:571) at Object.Module._extensions..js (internal/modules/cjs/loader.js:1051:10) at Module.load (internal/modules/cjs/loader.js:862:32) at Module._load (internal/modules/cjs/loader.js:774:14) at Function.Module._load (electron/js2c/asar.js:769:28) at Function.t._load (/usr/share/code/resources/app/out/vs/workbench/services/extensions/node/extensionHostProcess.js:1064:776) at Function.i._load (/usr/share/code/resources/app/out/vs/workbench/services/extensions/node/extensionHostProcess.js:1034:665) at Function.n._load (/usr/share/code/resources/app/out/vs/workbench/services/extensions/node/extensionHostProcess.js:1030:844) at Module.require (internal/modules/cjs/loader.js:899:19) at r (/usr/share/code/resources/app/out/vs/loader.js:17:346) at prepareSerialPort (/home/pi/.vscode/extensions/pycom.pymakr-1.1.11/pymakr.js:148:9) at activate (/home/pi/.vscode/extensions/pycom.pymakr-1.1.11/pymakr.js:7:5) at Function._callActivateOptional (/usr/share/code/resources/app/out/vs/workbench/services/extensions/node/extensionHostProcess.js:933:980) at Function._callActivate (/usr/share/code/resources/app/out/vs/workbench/services/extensions/node/extensionHostProcess.js:933:631) at /usr/share/code/resources/app/out/vs/workbench/services/extensions/node/extensionHostProcess.js:932:126 at processTicksAndRejections (internal/process/task_queues.js:94:5) at async Promise.all (index 5) at async Promise.all (index 0)
      /usr/share/code/resources/app/out/vs/workbench/workbench.desktop.main.js:3129 There was an error with your serialport module, Pymakr will likely not work properly. Please try to install again or report an issue on our github (see developer console for details)
      onDidChangeNotification @ /usr/share/code/resources/app/out/vs/workbench/workbench.desktop.main.js:3129
      /usr/share/code/resources/app/out/vs/workbench/workbench.desktop.main.js:304 [Extension Host] There was an error with your serialport module, Pymakr will likely not work properly. Please try to install again or report an issue on our github (see developer console for details)
      /usr/share/code/resources/app/out/vs/workbench/workbench.desktop.main.js:5407 Activating extension 'pycom.pymakr' failed: Could not locate the bindings file. Tried:
      → /home/pi/.vscode/extensions/pycom.pymakr-1.1.11/node_modules/@serialport/bindings/lib/binding/node-v80-linux-arm/bindings.node.
      _logMessageInConsole @ /usr/share/code/resources/app/out/vs/workbench/workbench.desktop.main.js:5407
        Are you running nodeJS on your pi? It seems from the logs it is not available. Have a look here:
        Dependencies
        NodeJS installed on your system (6.9.5 or higher) https://nodejs.org
          Tarun Nigam @Gijs
          @Gijs Hi, Can u please guide me further as I am new to the things and have very less background in software and concepts. Need step by step procedure please.
          • M Offline
            Matthew Felgate 0 Global Moderator @Tarun Nigam
            @Tarun-Nigam
            Hi Tarun,
            You can install nodejs in a terminal by writing: sudo apt install nodejs
            Then try Pyamkr again.
            Let me know if this works for you?
            Best regards
            Matthew
            T 2 Replies Last reply Reply Quote 0
              Tarun Nigam @Matthew Felgate 0
              @Matthew-Felgate-0 Thanks , will try this and get back to you on this. Want to see this thing working please.
                @Matthew-Felgate-0 Hi Matthew, Have installed nodeJS ,nodeJS version is 10.23.1, still facing problem.
                Please let me know further steps.
                  livius @Tarun Nigam
                  @Tarun-Nigam
                  question is if the problem is the same or message is different now?
                    Tarun Nigam @livius
                    @livius Facing same error, also I don't see Pymakr running in "Extensions Running" list in VS Code, Pls help.
                    • M Offline
                      Hi @Tarun-Nigam
                      Are you running this on a Raspberry Pi?
                      I think VS Code on Raspberry Pi is very new.
                      Can you do Pymakr > Extra > List Serial Ports and tell me what is says?
                      I think on the Raspberry Pi only 1 of the USB ports is a Serial Port.
                      Have you tried it plugging in to a different USB port?
                      Matt
                        @Matthew-Felgate-0 It does not accept the command, shows error
                        "Command 'Pymakr > Extra's > List serial ports' resulted in an error (command 'pymakr.extra.getSerial' not found)"
