    Capture and save the traceback from error
    lopylopy4traceback
    4 Posts 2 Posters 74 Views 2 Watching
    • M Offline
      M m
      I'm using my LoPys (lopy4) far away from my home, it means that if they have an error I can't go in a few days to see what's happening. Actually these days I'm having an error that I don't know what's happening.
      My question is, can I save in a txt file the traceback info? This is very interesting because I will know the file and line where the error happened and I don't need to be in real time watching the console.
      Actually I'm using the reset info, machine.reset_cause(), but is not enough.
      I thought using try/except but with this I can capture the exception, but not the callback. Furthermore I'm not sure I'm doing correctly because I have a try/except at the start of each file and this can't be optimum. Like
      # main.py
      try:
          # All my "main.py" code.
      except Exception as e:
          print(e) # Now I'm printing but I will write a txt file
      # myClock.py
      try:
          class Clock:
              def __init__(self):
                  # Code
              def func1(self):
                  # Code
          print(e)
      You know how to do this like a pro?
      Thank you very much!
      • K Offline
        kjm
          sys.print_exception(e)                                                    # see the traceback
          from uio import StringIO; s=StringIO(); sys.print_exception(e, s)         # puts traceback into variable s, does not actually print
          s=s.getvalue(); s.replace('"',"").replace("'",'')                         # remove quotes that might confuse error logging via https
        after this bit of massaging s is a sting you can save to a file. As provided to me by robert-hh (knowledgeable forum stalwart) a year or so ago when I was a python newbie.
        M 1 Reply Last reply Reply Quote 2
        • M Offline
          M m @kjm
          @kjm First of all, thank you very much for answering. I'm happy to see that I was in the correct way, but now my question is, where I have to put this code? In my main? In each function? In each class?
          • K Offline
            kjm @M m
            @M-m I put mine in a function def logtraceback(e): which I call from any Exception as e: where I want to log the traceback.
