    Couldn't connect to Modem (modem_state=disconnected)
    15 Posts 4 Posters 544 Views 7 Watching
    • K Offline
      kjm
      lte modem on a fipy ((1.20.2.rc9 with LR5.2.1.0-48829)) has gone AWOL. sqnsupgrade_info says "Cannot determine modem state!" Tried pycom.lte_modem_en_on_boot(1) as an act of desperation, didn't work.
      I googled the problem but no obvious solution. Can someone please suggest a method to get the modem back? I presume the problem is the internal uart interface between the fipy & the modem?
        To clarify, this did not happen during the update process right?
        Im assuming you already tried to disconnect power and reconnect it again, and that lte.factory_reset() is also not working for you. Could you try sqnsupgrade.info(debug=True) and let me know of the output
        K P T 3 Replies Last reply Reply Quote 0
        • K Offline
          kjm
          I finally got to the bottom of this. On this device with these firmwares the at+cfun=0 cmd (supposedly for switching the lte radio off) actually disconnects the lte modem uart. The only fix is to either stop using that particular cmd or recycle the power.
            @kjm Could you send an example code or some steps that we can take to reproduce this? Its not something that should happen I think, but I have no clear reproduction on what causes it
            K 1 Reply Last reply Reply Quote 1
            • K Offline
              kjm @Gijs
              @Gijs This
              import os, network, machine, time; begin=time.ticks_ms()
              def _t(): t=(time.ticks_ms()-begin)//1000; now='0'+str(t) if t<10 else str(t); return now
              def _end(reason): print(_t(), reason); machine.reset()
              print(_t(), os.uname()[1], os.uname()[2])
              print(_t(), 'lte'); lte=network.LTE()
              print(_t(), 'attach', end=' '); lte.attach()
              for i in range(9):
                time.sleep(1); print(i, end=' ')
                if lte.isattached(): print(); break
              else: print(); _end('attachment timeout')
              print(_t(), 'connect', end=' '); lte.connect()
              for i in range(2):
                if lte.isconnected(): print(); break
              else: print(); _end('connect timeout')
              print(_t(), 'switch off radio'); lte.pppsuspend(); lte.send_at_cmd('at+cfun=0')
              _end('finish')
              reliably sends the fipy modem awol here after the first run
              00 FiPy 1.20.2.rc9
              00 lte
              03 attach 0 1
              10 connect 0
              12 switch off radio
              17 finish
              00 FiPy 1.20.2.rc9
              00 lte
                File "<stdin>", line 9, in <module>
              OSError: Couldn't connect to Modem (modem_state=disconnected)
              There also seems to be some wifi issues this firmware as well in that the lopy is very reluctant to connect to the office router here, a problem we didn't have before we upgraded to 1.20.2.rc9
              This firmware doesn't flash the rgb led blue every 4s either (like earlier firmwares do when not running user code) so it's difficult to know what state the device is in too .
                Thanks for sending that through, I'll be testing your example, thanks a lot!
                You can re-enable the heartbeat (4s. flash) by using
                import pycom; pycom.heartbeat_on_boot(True).
                Im not familiar with the wifi issues you mention, we do sometimes have issues with our router though, where it stops broadcasting the 2.4GHz WiFi network, but other than that Im not aware of issues with devices and connecting. Perhaps you could elaborate? Though I have no clue where the issue would be, if there is one.
                • K Offline
                  kjm @Gijs
                  @Gijs I'm perusing a hunch that maybe the fipy is deafer to wifi than our gpys because of the inability to switch off the lora radio, maybe caused by some local oscillator leakage? The fipy definitely reports lower wifi signal strengths than the gpys in the same location.
                    That is quite a hunch you got there :). To be honest I'd have to check that in more detail (In my quick test here using this example code, I was not able to spot a noticeable difference over time between a Lopy4, Fipy or Gpy sitting right next to each other):
                    from network import WLAN
                    wlan = WLAN(mode=WLAN.STA)
                      nets = wlan.scan()
                      for net in nets:
                        if(net.ssid == 'ssid'):
                          print(net.ssid, net.rssi)
                      time.sleep(10)
                    Do you perhaps have different devices to test your hunch with?
                    For the original issue, Im currently having some reception issues from within the office, but It's still on my list!
                    • K Offline
                      kjm @Gijs
                      @Gijs Got another uncommunicative sequans modem Gijs
                      >>> import sqnsupgrade
                      >>> sqnsupgrade.info(debug=1)
                      <<< Welcome to the SQN3330 firmware updater [1.2.6] >>>
                      >>> GPy with firmware version 1.20.1.r1
                      The current delay is 1000
                      Response (+++ #1): None
                      Response (AT #1) None
                      Response (AT #3) None
                      Response (AT #4) None
                      Response (AT #1 @ 115200) None
                      Response (AT #2 @ 115200) None
                      The current delay is 2000
                      The current delay is 3000
                      The current delay is 4000
                      The current delay is 5000
                      Modem state: None
                      The lte.factory_reset() is not option since an uncommunicative modem means I can't create an lte. Any other ideas I can try?
                        Either the modem is talking on a wrong baudrate, or wrong UART, or bootrom, or you have an issue with the communication pins (perhaps you attached some device to it, or an internal issue in the esp32), or you need a power cycle. As a last resort, the LTE modem could be fryed.
                        To solve the first two cases, you can check different baudrates using:
                        from machine import UART
                        # Open serial connection to LTE modem
                        serial = UART(1, baudrate=921600, pins=('P20', 'P18', 'P19', 'P17'), timeout_chars=1)
                        # For example write AT to modem
                        serial.write("AT" + '\r\n')
                        # Read back the response from the modem
                        time.sleep(3)
                        print(serial.read())
                         # Deinit uart to lte modem
                        serial.deinit()
                        Next to that, safebooting might help
                        The wrong UART port is a bit more complicated (using testpads on the bottom of the Fipy), if needed I can elaborate.
                        • K Offline
                          kjm @Gijs
                          @Gijs Response was None, no joy from safe booting. The only event suffered by this gpy is the lipo powering it went flat due failed solar panel, so hoping the modem is recoverable. Underside test pads is sounding fiddly, how likely is it that the modem would be on the wrong baud or port? Wouldn't the modem firmware have only 1 value for each, namely the value appropriate for the gpy? Maybe I should be writing code to deepsleep everything once the lipo hits 3.4v if permanent modem loss is going to be a by product of low battery voltage operation?
                          Also your suggested code gives the same result (None) on a gpy with a working modem, what baud should the gpy & the sequans chat on?
                            I'm not sure what the chance is of the modem talking on a different UART, or whether that is what is the case here. Though there exist some AT commands that change the UART settings, and there is some recovery bootloader mode that uses a different UART that should always be accessible. If you send me a message over at support@pycom.io I can talk you through reading the other UART ports (it is indeed somewhat fiddly).
                            For a Gpy, the pins are different. I thought we were discussing the Fipy. For the Gpy, you should use ('P5', 'P98', 'P7', 'P99').
                            • K Offline
                              kjm @Gijs
                              @Gijs said in Couldn't connect to Modem (modem_state=disconnected):
                              Tnx for gpy appropriate pin nums Gijs. Sadly the gpy with the uncommunicative sequans has become obstinate itself
                              waiting for download
                              is all I can get out of it now. Erased the flash & reloaded the firmware but no change. Any tips on recovering dead GPYs?
                                pottendo pottendo @Gijs
                                hi,
                                I have the same problem - on a Gpy, running:
                                Pycom MicroPython 1.20.2.r4 [v1.11-ffb0e1c] on 2021-01-12; GPy with ESP32
                                Here's my output:
                                ets Jun  8 2016 00:22:57
                                configsip: 0, SPIWP:0xee
                                mode:DIO, clock div:1
                                load:0x3fff8020,len:8
                                load:0x3fff8028,len:2128
                                load:0x4009fa00,len:19760
                                entry 0x400a05bc
                                Smart Provisioning started in the background
                                See https://docs.pycom.io/smart for details
                                Pybytes Version: 1.6.1
                                >>> import sqnsupgrade; sqnsupgrade.info()
                                >>> GPy with firmware version 1.20.2.r4
                                Modem state: None
                                This state was entered when using the Linux cmd-line to flash the CATM1 Firmware via USB after having the NB-IoT installed some weeks ago using the same method.
                                Python 3.9.5 (default, May 11 2021, 08:20:37)
                                [GCC 10.3.0] on linux
                                Type "help", "copyright", "credits" or "license" for more information.
                                >>> import sqnsupgrade
                                >>> sqnsupgrade.run('/dev/ttyACM0', '/work/src/arduino-play/pycom/CATM1-5.2-48829/CATM1-5.2-48829-1.dup', load_fff=False)
                                <<< Welcome to the SQN3330 firmware updater [1.2.7] >>>
                                Attempting AT wakeup...
                                Session opened: version 1, max transfer 8192 bytes
                                Sending 416448 bytes: [########################################] 100%
                                Waiting for modem to finish the update...
                                <<<=== DO NOT DISCONNECT POWER ===>>>
                                Resetting.....................................................................................................................................................................................................................................................................................................................................................Traceback (most recent call last):
                                  File "/opt/work/src/arduino-play/pycom/pycom-libraries/lib/sqnsupgrade/sqnsupgrade.py", line 1076, in run
                                    sqnup.upgrade_ext(port=port, ffile=ffile, mfile=mfile, resume=resume, debug=debug, pkgdebug=False, verbose=verbose, load_fff=load_fff, force_fff=force_fff)
                                  File "/opt/work/src/arduino-play/pycom/pycom-libraries/lib/sqnsupgrade/sqnsupgrade.py", line 948, in upgrade_ext
                                    if self.__run(file_path=ffile, resume=True if mfile is not None else resume, direct=False, port=port, debug=debug, pkgdebug=pkgdebug, verbose=verbose, load_fff=load_fff, fc=fc, force_fff=force_fff):
                                  File "/opt/work/src/arduino-play/pycom/pycom-libraries/lib/sqnsupgrade/sqnsupgrade.py", line 719, in __run
                                    self.wait_for_modem(send=False, echo_char='.', expected=b'+SYSSTART')
                                  File "/opt/work/src/arduino-play/pycom/pycom-libraries/lib/sqnsupgrade/sqnsupgrade.py", line 150, in wait_for_modem
                                    raise OSError('Timeout waiting for modem to respond!')
                                OSError: Timeout waiting for modem to respond!
                                I hope the modem can be somehow recovered.
                                If not I fear the Gpy is not suitable for our projects... :-(
                                thx, pottendo
                                  Tarmo Saluste @Gijs
                                  I have the same problem.
                                  Response (AT #3) b'\x00'
                                  Response (AT #2 @ 115200) b'\x00'
                                  Response (AT #4) b'\x00'
                                  Response (AT #1 @ 115200) b'\x00'
                                  Response (AT #1) b'\x00'
                                  Response (AT #2) None
                                  Response (+++ #2): None
                                  Response (AT #4) b'\x00\x00'
                                  Response (+++ #1): b'\x00'
                                  Response (AT #3) b'\x00\x00'
                                  Response (AT #2 @ 115200) b'\x00\x00'
                                  Response (AT #4) b'\x00\x00\x00'
                                  Response (AT #1 @ 115200) b'\x00\x00'
                                  Modem state: None
