    Noob question: how to send data through bluetooth
    bluetoothfipytransmitdataphone
    3 Posts 2 Posters 100 Views 2 Watching
    • F Offline
      Francesco Pasculli
      Hi everyone, I would like to transmit light intensity measurement through bluetooth but I cannot understand how to do this since I'm a pycom noob and it is not very clear to me the mechanism, I think I lack some basics concepts.
      After some attemps I was able to connect to my phone and discover my Fipy using BLE Scanner app but I don't know how to continue.
      This is my code at the moment
      from network import Bluetooth
      import ubinascii
      from pycoproc_2 import Pycoproc
      from LTR329ALS01 import LTR329ALS01
      pycom.rgbled(0x0A0A08) # white
      py = Pycoproc()
      pybytes_enabled = False
      if 'pybytes' in globals():
          if(pybytes.isconnected()):
              print('Pybytes is connected, sending signals to Pybytes')
              pybytes_enabled = True
      lt = LTR329ALS01(py)
      bt = Bluetooth()
      bt.set_advertisement(name='FraccaPy', service_uuid=b'1234567890123456')
      bt.advertise(True)
      if not bt.isscanning():
          bt.start_scan(-1)    # start scanning with no timeout
      print('Trying to establish connection with Nord')
      connection = bt.connect('ac5fea133f19')
      if (connection.isconnected()):
          print ('Successfully connected to Nord')
      # while True:
      #     time.sleep(1)
      #     # print read data on screen
      #     print("Light [channel Blue lux, channel Red lux]: " + str(lt.light()))
      #     # switch on led graduated in relation to external light
      #     red = lt.light()[1]*0.5
      #     blue = lt.light()[0]*0.5
      #     led = round (red + blue)
      #     pycom.rgbled(led << 8)
      #     # transmit data via Wi-Fi
      #     if(pybytes_enabled):
      #         pybytes.send_signal(1, lt.light())
      Any help would be greatly appreciated, thanks in advance.
        We recently provided an example for this here: https://docs.pycom.io/tutorials/networks/ble/callback/
        Let me know if that works for you
        F 1 Reply Last reply Reply Quote 0
        • F Offline
          Francesco Pasculli @Gijs
          @Gijs actually I solved my problem before seeing this , anyway it is very interesting.
          In particular, my problem was solved by removing
          I found out these commands were not needed and they broke my code.
