    how to pip3 install properly in order to use LoRa?
    9 Posts 5 Posters 116 Views 5 Watching
      Axel Carré
      I'm doing a school project and I received a PyCom device that I'm using on my Raspberry in Python programs.
      My teacher provided me a code but actually I don't understand what I have to pip3 install in order to compile these two imports only: from network import LoRa and import ubinascii. I've managed to understand (I think) that they are from MicroPython but I can't any tutorial on how to setup all of this.
      I have the whole code (which I wasn't supposed to do, just run along with my own piece of code) but I just can't find a way to make it all work... :(
      Thanks in advance!
        robert-hh @Axel Carré
        @Axel-Carré pip3 is a installer for the PC handling python3 packages, but the imports you mention run on the LoPy devices. So they are not related. I understand that this is confusing.
        And the pip3 command is not complete. It does not show what pip3 should install.
        A 1 Reply Last reply Reply Quote 1
          Axel Carré @robert-hh
          @robert-hh Alright so do you know by any chance how to install all the needed libraries?
            @Axel-Carré both network and ubinascii are already embedded into the LoPy4 (I assume it's the one) firmware. So you do not need to install it on the device.
            Edit: You can tell which modules are pre-installed on the Pycom device by the following command in the REPL:
            help('modules')
            Then you get a list of installed modules.
            >>> help('modules')
            __main__          machine           sys               upysh
            _boot             math              time              uqueue
            _main             micropython       ubinascii         ure
            _thread           mount             ubinascii         uselect
            array             network           ucollections      uselect
            binascii          os                ucrypto           usocket
            builtins          pycom             uctypes           ussl
            cmath             pye_mp            uerrno            ustruct
            crypto            queue             uerrno            utime
            errno             re                uhashlib          utimeq
            framebuf          select            uio               uzlib
            gc                socket            ujson
            hashlib           ssl               umachine
            json              struct            uos
            Plus any modules on the filesystem
            P.S.: Both modules do NOT exist on the Raspberry Pi. There may be a network module, but with different classes. And instead ubinascii there is binascii. But that is irrelevant, since you have to run your code on the Pycom device, not on the RasPi.
            K 1 Reply Last reply Reply Quote 1
            • K Offline
              kjm @robert-hh
              @robert-hh Just curious Rob, why are there 2 copies of ubinascii, uselect, etc?
                robert-hh @kjm
                @kjm Some modules have a non-u alias for compatibility. Don't ask me why some have and others not. But it's only an alias. The module itself exists only once.
                  livius @robert-hh
                  @robert-hh
                  He ask about same name not without "u" ;-)
                  there are e.g. 2xuselect 2xubinascii 2xuerrno
                    robert-hh @livius
                    @livius right. I did not see that, and I have no clue why, and why only these three.
                      I looked around in the firmware to find any double definitions, but could not find anything concrete why these three are duplicated. Though its probably limited to only the help-function printing code, meaning there's no fundamental flaw in the firmware
