    sqnsupgrade.info() result a coredump
    ltefipycoredump
    3 Posts 2 Posters 116 Views 2 Watching
      tttadam
      Hey there,
      Nothing I can add..
      When I want to check the LTE modem firmware version I got a coredump. Is it how it supose to work? Thanks! :)
      >>> import sqnsupgrade
      >>> sqnsupgrade.info()
      <<< Welcome to the SQN3330 firmware updater [1.2.6] >>>
      >>> FiPy with firmware version 1.20.2.r4
      UE5.2.0.3
      LR5.2.1.0-48829
      IMEI: 354346092128320
      Guru Meditation Error: Core  0 panic'ed (StoreProhibited). Exception was unhandled.
        The coredump is an unfortunate bug in the script. Though the function does return all firmware versions you need before it coredumps. All other functionality of sqnsupgrade is fine.
          tttadam
          I tried the legacy firmware without the pybytes stuff.
          It is works all right with that fw.
