    OSError: no network card available after newest firmware update
    2 Posts 2 Posters 88 Views 2 Watching
    • Z Offline
      Zino Henderickx
      Hello everyone,
      I updated my latest firmware from the Pycom Lopy 4 (v.1.20.2.r4) and since ever then I can't send data over WiFi and I also can't change from protocol because it is for a task at the University.
      This is my main code:
      from machine import Pin
      from time import sleep_ms
      import urequests
      btn = Pin('P16', Pin.IN, Pin.PULL_UP)
      btn2 = Pin('P17', Pin.IN, Pin.PULL_UP)
      btn3 = Pin('P18', Pin.IN, Pin.PULL_UP)
      btn4 = Pin('P19', Pin.IN, Pin.PULL_UP)
      led = Pin('P20', Pin.OUT, Pin.PULL_DOWN)
      def irq_function_sad(self):
          if not btn.value():
              led.value(1)
              print("ongelukkig")
              sleep_ms(500)
              send_sad("ongelukkig")
              led.value(0)
      def send_sad(sad):
          res = urequests.post('http://xxxxxx', json={"emotie": sad})
          res.close()
          if (res.status_code - 200) < 100: # check that response code is in the 200 range
              print('done')
              print('there was some error')
      def main():
          btn.callback(Pin.IRQ_FALLING, irq_function_sad)
              print(btn.value())
              time.sleep(2)
      if __name__ == "__main__":
          main()
      My error:
      Unhandled exception in callback handler
        File "main.py", line 18, in irq_function_sad
        File "main.py", line 24, in send_sad
        File "/flash/lib/urequests.py", line 116, in post
        File "/flash/lib/urequests.py", line 56, in request
      OSError: Network card not available
      Can someone help me please? Or did someone had the same problem?
      Kind regards,
      Zino
        It seems you never instantiate a network. Perhaps in 1.18 you were using the pycom.wifi_on_boot (etc. from here: https://docs.pycom.io/firmwareapi/pycom/pycom/#pycomwifi_on_bootboolean) settings which might have been erased when you did the firmware update?
        In any case, you should be able to add the example from here: https://docs.pycom.io/tutorials/networks/wlan/#connecting-to-a-router to your main() to resolve the issue.
