    FiPy as LoRa gateway + LTE transmitter
    fipyltelora gatewayloragateway
    3 Posts 2 Posters 96 Views 2 Watching
    • H Offline
      Hazel Mitchell
      Hi all,
      I'm developing a LoRaWAN-based sensor network and need a gateway that can receive the LoRa messages from sensor nodes, then transmit the data over 4G. I was going to use one of these: https://store.rakwireless.com/products/rak7243c-pilot-gateway?variant=39945345007814 (RAK7243C) but they're out of stock everywhere.
      Would a FiPy be able to do the same thing?
      Alternative suggestions also appreciated.
      Thanks in advance!
        jcaron @Hazel Mitchell
        @Hazel-Mitchell A FiPy alone can only listen on a single LoRa channel at a time, which is not compatible with it being a real standards-compliant LoRaWAN gateway. You can use the "nano-gateway" script from the docs to make it a single-channel gateway, but end devices and/or the network will need to be adjusted to reflect this, otherwise you'll end up with huge packet loss.
        If you want a real gateway you'll have to go for the PyGate. However IIRC you can't use a FiPy with that, but you can use a GPy to get the LTE backhaul.
        Note that a gateway is power-hungry, so you'll need an external power source (not batteries).
        H 1 Reply Last reply Reply Quote 2
        • H Offline
          Hazel Mitchell @jcaron
          @jcaron Thanks for the info!
