Sigfox and SSD1306
Im trying to create a Sigfox signal tester using the return RSSI using a Fipy and a SSD1306 OLED
im getting an error in relation to SSSD1306. i have a script from the following.
https://github.com/pycom/pycom-micropython-sigfox/blob/master/drivers/display/ssd1306.py
i get the following error>>> >>> ♦Traceback (most recent call last): File "<stdin>", line 12, in <module> File "ssd1306.py", line 109, in __init__ File "ssd1306.py", line 37, in __init__ File "ssd1306.py", line 64, in init_display File "ssd1306.py", line 89, in show File "ssd1306.py", line 119, in write_data AttributeError: 'I2C' object has no attribute 'start' ♦> Pycom MicroPython 1.20.2.r4 [v1.11-ffb0e1c] on 2021-01-12; FiPy with ESP32 Pybytes Version: 1.6.1 Type "help()" for more information. >>>```my main.py code is below
from machine import I2C, Pin from network import Sigfox from ssd1306 import SSD1306_I2C import socket #i2c = I2C.init(0, I2C.MASTER, baudrate=100000, pins=("P10","P10")) #INITIALIZATION AFTER POWER UP i2c = I2C(0, I2C.MASTER) # create and init as a master # configure the I2C bus i2c.init(I2C.MASTER, baudrate=400000) # init as a master oled = SSD1306_I2C(128, 32, i2c, 60,external_vcc=True) sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ4) s = socket.socket(socket.AF_SIGFOX, socket.SOCK_RAW) s.setblocking(True) s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, True) s.send(bytes([0, 1, 2, 3])) r= s.recv(32) print(r) rssi=sigfox.rssi() print(rssi()) oled.text(rssi, 0, 0, 1) oled.show() s.close() -
@alexlont said in Sigfox and SSD1306:
SSSD1306
It is quite old. Try to use it from official micropython it use framebuffer then
https://github.com/micropython/micropython/blob/master/drivers/display/ssd1306.py -
@livius I've updated my SSD1306.Py script to refect the newer library. however im still getting the exact same issues.
Pybytes configuration read from /flash/pybytes_config.json Traceback (most recent call last): File "main.py", line 7, in <module> File "ssd1306.py", line 109, in __init__ File "ssd1306.py", line 37, in __init__ File "ssd1306.py", line 64, in init_display File "ssd1306.py", line 89, in show File "ssd1306.py", line 119, in write_data AttributeError: 'I2C' object has no attribute 'start' Pycom MicroPython 1.20.2.r4 [v1.11-ffb0e1c] on 2021-01-12; FiPy with ESP32 Pybytes Version: 1.6.1 Type "help()" for more information. >>> -
@alexlont
Are you sure that you are using this new one?
There is no start command in the new code. -
@livius The new version uses
i2c.writevto, though, which does not seem to exist in Pycom firmware (at least it's not documented, didn't check an actual device or the sources).But the error message should be slightly different, the error shown clearly points to the older version of the driver.
