    FiPy does not connect to LTE
    2 Posts 2 Posters 52 Views 2 Watching
      Dewakar Kanday
      Hi There, I am facing an issue where the FiPy is unable to connect to the LTE. I have tried 3 different SIMs(Tmobile, AT & T and Arduino) and have the same issue.
      When I run the below code, it keeps displaying this info:
      SYSTEM FSM
      |            FSM           |        STATE       |
      | RRC TOP FSM              |SCANNING            |
      | RRC SEARCH FSM           |WAIT_RSSI           |
      | RRC ACTIVE FSM           |NULL                |
      | PMM PLMN FSM             |NORM_WAITCELL       |
      | EMM MAIN FSM             |NULL                |
      | EMM AUTH FSM             |NULL                |
      | EMM CONN FSM             |NULL                |
      | EMM TAU FSM              |NULL                |
      | EMM TEST FSM             |NULL                |
      | ESM BEARER FSM           |BEARER_NULL         |
      | SMS MT FSM               |IDLE                |
      | SMS MO FSM               |IDLE                |
      | LPP FSM                  |IDLE                |
      | HP MAIN FSM              |IDLE                |
      | HP USIM FSM              |READY               |
      | HP SMS MO FSM            |IDLE                |
      | HP SMS MT FSM            |IDLE                |
      | HP CAT FSM               |IDLE                |
      from network import LTE
      lte = LTE()
      #some carriers have special requirements, check print(lte.send_at_cmd("AT+SQNCTM=?")) to see if your carrier is listed.
      #when using verizon, use
      #lte.init(carrier=verizon)
      #when usint AT&T use,
      #lte.init(carrier=at&t)
      #some carriers do not require an APN
      #also, check the band settings with your carrier
      lte.attach(band=20, apn="your apn")
      print("attaching..",end='')
      while not lte.isattached():
          time.sleep(0.25)
          print('.',end='')
          print(lte.send_at_cmd('AT!="fsm"'))         # get the System FSM
      print("attached!")
      lte.connect()
      print("connecting [##",end='')
      while not lte.isconnected():
          time.sleep(0.25)
          print('#',end='')
          #print(lte.send_at_cmd('AT!="showphy"'))
      print("] connected!")
      print(socket.getaddrinfo('pybytes.pycom.io', 80))
      lte.deinit()
      #now we can safely machine.deepsleep()
        Please check the page here: https://docs.pycom.io/tutorials/networks/lte/#lte-troubleshooting-guide. Can you confirm the simcards are specifically for NB-IoT and/or CAT-M1 LTE networks, and not the regular 4G mobile phone simcards? also confirm with the carrier whether the there is coverage in your region
