Crashing after a couple of hours
Hi I'm setting up a temperature sensor using the gPy device. My idea was to have it in deepsleep for ~30 minutes and then perform a measurement and go back to sleep.
I've created a main.py that looks like this:
from machine import Pin import time from onewire import DS18X20, OneWire print("Booted into application at {}".format(time.time())) def get_temperature(): """Get temperature from OneWire sensor.""" ow = OneWire(Pin('P10')) temp = DS18X20(ow) for _ in range(10): temperature = temp.read_temp_async() time.sleep(1) temp.start_conversion() if temperature: break return temperature def publish_to_web(temperature): print('Publishing a temperature of {}'.format(temperature)) pybytes.send_signal(0, temperature) time.sleep(1) temperature = get_temperature() publish_to_web(temperature) time.sleep(1) print("Going to sleep") pybytes.deepsleep(30*60*1000) # 30 MinutesAnd this works for some time but after 5-8 hours samples stop coming in and when looking at my computer I see that the Atom shell is trying to connect to the serial port but failing.
Disconnecting / reconnecting then shows a
SyntaxErrormessage. Resetting the device resumes the operation.Has anyone seen anything similar to this? Any ideas how to make it more robust? Could I setup a watchdog in the boot.py and then feed / disable it in my main.py? would it help or is it likely that the issue occurs earlier.
I've now connected it to an usb-charger in case there's something my computer does.
Any help / insights would be appreciated!
Having it plugged to an usb-charger instead of the computer's usb has kept it stable since I sent above message so maybe it was the USB port on my computer or possibly Atom causing the issue.
